Old 08-24-2009, 07:33 AM
automatic8 automatic8 is offline
Default Drum Miking uestion
I recently got some drum tracks sent to me that were done at another studio. To my surpirise they sound great! Each drum was close miked with a room and an over head. Heres my question..... there was only one overhead on a mono track. How would i get my stereo drum sound from just this one mic? My first intention would be to just duplicate the track and drag one of them back .015 milliseconds or so and pan hard left and right. I guess id do the same with the mono room track? Any insight or tips would be appreciated as I am new to mixing a real kit
Thanks!
Old 08-24-2009, 07:39 AM
marmotman's Avatar
marmotman marmotman is offline
Default Re: Drum Miking uestion
there's a pretty good thread/argument here: http://www.gearslutz.com/board/so-mu...-overhead.html
To be honest, my preferred method on this kind of thing is get a good room reverb (mono>stereo) on the channel and have the mix at around 80% wet. Compress the hell out of it and hey presto, wide drums.
Drink up, dreamers... you're running dry
Old 08-24-2009, 07:45 AM
Chase743 Chase743 is offline
I would not duplicate them like that, unless you're going for a very specific effect. It probably won't sound natural.
My suggestion, and it is hard to say without listening, is to pan your room mic in one direction and the OH in the other. You have to use your ears to find the right %s.
Also, try sending the close mics to a stereo 'verb. That'll open up the sound a bit too.
PC: Dell Studio XPS 9000
Hardware: 002r, Mbox 2, Digimax D8, ART Pro MPA II (w/ Mullard Tubes)
Guitarist | Singer | Songwriter | Engineer
www.stolenalibi.com
Old 08-24-2009, 08:06 AM
I agree. I would start by pulling the mono room mic way down and get the mix of the drums sounding good. The I would use aux sends to a stereo aux track with a good reverb plugin(I like the IK Classik Verb room for this, or TL Space with a nice room convolution). The stereo room verb will help spread the kit and then I will slide the mono room track up to give the kit a bit more focus(assuming it sounds good). Remember, as cool as panning is, it can also get unrealistic. If you imagine a stage and spread your drums out too far, its fun, but not real sounding. +1 for experimenting with some limiting on the room mics. Another thing I do a lot is, aux send the drums to a stereo aux track and insert Waves SSL bus compressor(or BF76) and slam the compressor. Then mix that up under the rest of the drums.(other compressor plugins may have latency that causes phasing but these 2 work good for this).
Old 08-24-2009, 08:19 AM
TOM@METRO's Avatar
Thanks!
I wouldn’t be all that concerned. Many hit recordings have been done with a mono overhead. The bleed into the close mics will still offer a reasonable stereo image unless you gate them to death..
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 08-24-2009, 08:24 AM
thanks for all the great advice. Ill be sure to give the stereo aux verb a try. Guess ill stay away from the duplicating/delay and hard pan option. I can totally see how a mono track would make more sense than a fake stereo track.
Old 08-24-2009, 08:31 AM
would a plate verb be a good start for the room and overhead?
Old 08-24-2009, 09:11 AM
mano111 mano111 is offline
I'd instinctively say no, but it could.
I'd go with (the already suggested) TLSpace natural sounding room mono/stereo, you could possibly pan the stereo back to 60-60 or so for a less wide feel. too wide on drums often sounds fake.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 09-02-2009, 02:40 AM
marmotman's Avatar
This is true... even when using something like EXDrummer / Superior / whatever... its best to send all your individual drum channels to a submix and have that stereo channel panned at 64 l/r MAXIMUM but have any hall-type verbs on aux sends still at full 100 l/r with a hefty cut before it at around 160Hz to get rid of the bottom end. Mmmm.... clarity!
Having a submix is dead useful for overall comp and EQ - normally courtesy of some Bomb Factory plugs ;-)
Kick drum miking xterraguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 03-12-2009 05:40 AM
easy Drum machine/MIDI ?uestion.... cerebral 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-01-2005 06:18 AM
Drum Miking with 002 and PTLE eminentbliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-15-2004 02:15 PM
drum miking JFreak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-31-2003 10:28 AM
Drum Overhead Miking? Erik Braund Tips & Tricks 18 12-13-2001 06:35 AM
