Old 11-24-2014, 02:28 PM
fsguerra fsguerra is offline
Default AAE error 2 was encountered. HELP!
Good afternoon, all.
After the 11.2.2 install I started seeing the AAE error 2 was encountered message when opening existing sessions. Creating new sessions seems to work fine.
I checked the knowledge base couldn't find the meaning of this error.
Anyone?
Regards,
Francisco
Pro Tools 11.2.2
Mac Pro Late 2013
Yosemite 10.10.1
UA Apollo
Old 11-24-2014, 02:33 PM
Could this be a Yosemite situation ?
Have you tried making a new session then importing session data from the old session ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 11-24-2014, 05:33 PM
Default Re: AAE error 2 was encountered. HELP!
Thanks for the response.
I was able to import the problem session data into a clean session. No AAE error appears.
Regards,
Francisco
Old 11-24-2014, 06:06 PM
Restarted the computer. It appears that my sessions is fine.
Rebooting ever fails! :)
I am still curious as to what the root/cause of that issue is.
Old 11-24-2014, 11:22 PM
Hhmm. Well … there do seem to be a lot of "don't upgrade to Yosemite" notes / warnings around.
Old 11-25-2014, 05:26 AM
clive.gardner clive.gardner is offline
Not sure if this is a Yosemite specific issue. I'm getting constant AAE error 2's under 11.2.2 on Windows, something I didn't see with previous versions.
Old 11-25-2014, 05:53 AM
nhaudio nhaudio is offline
I get these errors occasionally after importing session data, then recalculating waveforms (as the waveforms often don't show up on the imported tracks... another bug). Closing and re-opening the session clears it up quickly, though.
ProTools HDX 11.2.1 on Mac OS 10.9.4.
MacPro 6,1, 6-core, 32 GB RAM
Old 06-19-2015, 06:47 AM
tallshon tallshon is offline
I have this same issue but I have it on a windows computer. Every time i try to do a play back or if i record something and play it back this error comes up.
ProTools HDX 11.2.1 on Windows 7
Lenovo 64 Bit - i5-4300m cpu 1TB
Old 07-12-2015, 10:59 PM
dizzyzuma dizzyzuma is offline
tallson, did you ever resolve this error? I am in the same boat.
Zuma
M-box II Pro
Windows 7
Old 01-05-2016, 04:24 PM
rcarline rcarline is offline
Make sure no identically named disks are mounted, quit ProTools and relaunch it.
Help! I get the error 'pro tools has encountered an unrecognized component' error gsmith135 Windows 10 12-17-2014 01:08 PM
error 706 was encountered Russkull Pro Tools TDM Systems (Mac) 2 08-25-2008 09:23 AM
DAE error 7 encountered. Smoovie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-22-2004 07:55 AM
DAE error was encountered while trying to connect (error #-7101 Enis Presheva Jr. Pro Tools TDM Systems (Mac) 1 06-07-2001 12:45 AM
DAE Error -50 was encountered HELP! MacDigidesign Digidesign Hardware & Software 4 10-26-2000 06:39 PM
