Old 07-04-2013, 09:07 AM
BuckleySound BuckleySound is offline
Default Cheapest and easiest solution to upgrade to Pro Tools 11HD
I am looking to invest in upgrading my full recording setup.
I currently rock Pro Tools LE 8 and want to upgrade to 11HD.
What would be the simplest and cheapest way to do this?
Cheers
Matt
Old 07-04-2013, 09:28 AM
Craig F Craig F is offline
Default Re: Cheapest and easiest solution to upgrade to Pro Tools 11HD
by 11HD do you just want the software or do you want the hardware as well?
Thank you,
Craig
Old 07-04-2013, 12:06 PM
nst7 nst7 is offline
The cheapest way would be an HD Native system. There is a trade in deal if you have a 002, 003, or Mbox Pro. It looks like you have a regular Mbox 2. You might talk to your dealer and see if they can ask Avid if they will take the regular Mbox for the deal.
Old 07-04-2013, 01:40 PM
Cheers Guys.
Im looking at just getting the software. To be used for recording live shows and mix on the go with more than 32 Channels.
Old 07-04-2013, 01:58 PM
for more than 32 channels of simultaneous recording you need HD hardware
so a HDN Thunderbolt is probably your best option then eather 3 HD I/O intefaces each loaded with 2 ADC cards for 48 analog in or the MADI box for 64 I/O if you can tap a MADI feed
HD software does not override the 32 channel cap if using Core Audio/ASIO interfaces
Thank you,
Craig
Old 07-05-2013, 03:24 AM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
... and that's Pro Tools only ... ANY other DAW (even the free ones) will easily support as many tracks as your hardware allows.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 07-05-2013, 03:50 AM
Mista Min Mista Min is offline
But once you get into that kind of channel count and high end conversion, ie RME, SSL, REDNET, Apogee, etc... Your already in the same ball park... Why not just invest into a full integrated system that works and includes your DAW. I mean you have to like Pro Tools for this to e worthwhile but HD Native and HDX is in my opinion not that expensive when I consider my other options that offer similar results.
Old 07-05-2013, 05:41 AM
JFreak's Avatar
JFreak JFreak is offline
Basically if you buy into PT HD with enough tracks you get the software for free. And if you want to use 3rd party hardware for your tracks you're limited to 32 tracks even if you paid for the software in an unofficial way.
PT HD Native supports 64 tracks and is not that expensive. The cost comes from the interfaces (tracks).
Janne
Old 07-05-2013, 01:40 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
"Cheapest and easiest solution to upgrade to Pro Tools 11HD"
Dont....
Read the forum posts on 11 before you invest in it... download the demo and see if you like it... also you cant get PT11 HD as just software it bundles with hardware... you can get PT 11 non HD though, but then it goes back to my original post... Dont
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Why is there no upgrade from 8HD to 10/11HD? michael c Pro Tools 11 9 10-02-2013 11:04 AM
WTB:Pro Tools 10 HD(upgrade from 9HD) NOT 11HD TMJRecordings Buy & Sell 1 08-29-2013 12:02 PM
Pro Tools 11HD Upgrade Question. philip888 Pro Tools 11 1 08-28-2013 06:56 AM
Fastest/cheapest/easiest way to add outputs to 192 KenSluiter Pro Tools TDM Systems (Mac) 4 04-16-2005 03:30 PM
Cheapest Backup Solution? marknolan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-16-2004 04:18 AM
