Akai LPD8 Pro Tools 9
My LPD8 which is brand new is plugged into my PC via USB and shows up in the I/O drop bar in pro tools on the midi tracks so it is enabled. For some reason when I play on the pad no signal goes into the channel. To put it simply. Something should be happening but nothing is. What the flup do I do?
Re: Akai LPD8 Pro Tools 9
I'd like to know if you found out how to fix this problem, as I'm having the same issue.
Akai LPD8 Pad Controller | Rwilliams0190 | MIDI | 2 | 01-18-2021 05:14 PM |
AKAI LPD8 Knobs | ajhous | Windows | 2 | 12-19-2013 01:37 PM |
How to Config PT 8 & Akai LPD8 | bootybandit | The Drum Room | 5 | 06-06-2010 12:57 PM |
Basic Midi HELP: PT 8 & Akai LPD8 | bootybandit | MIDI | 0 | 01-06-2010 04:31 AM |
Akai LPD8 and LDK25 controllers with MPowered 8.0.1 | cmangeot | Pro Tools M-Powered (Win) | 1 | 11-10-2009 09:59 AM |
