  #21
Old 10-26-2009, 12:58 PM
DigiTechSupt's Avatar
Default Re: Pro tools 8 LE unable to receive midi
Ok, since we know that you're using Kontakt, can I ask which version of Kontakt you have installed? Also do you possibly have any incompatible plug-ins installed - you can compare your installed versions to the compatibility grid (more info in the General Troubleshooting thread).
My guess is that an incompatible plug-in is causing this - older versions of Kontakt have been known to create strange MIDI problems like you're describing.
Avid Audio Tech Support
Support FAQ
  #22
Old 10-28-2009, 06:22 AM
ebooker ebooker is offline
My issue is similar, when trying to playback with midi enabled PT 8.0.1 loops first note and freezez whole system. This started with the upgrade. Never had this issue before....
  #23
Old 10-28-2009, 12:11 PM
It would help immensely if you can post more details about what you've tried, your system specs, etc.
Especially important are all the settings/possible fixes given in this thread. Which ones have you done?
And can you use the Tech Support Utility from the General Troubleshooting thread to generate and post an installed plug-in list?
Support FAQ
  #24
Old 10-29-2009, 03:44 AM
mojovoodoo mojovoodoo is offline
i am having the same problems all day long. i have been doing all of the trouble shooting issues. trashing preferences. trashing databases. emptying trash. restarting the computer. all sorts of things. yet, still i cannot get any MIDI signal, and i am just using Xpand. funny, when i use reason in PT 8.0.1, it works in the reason plugin, but, when i just wanna use Xpand, and save on my CPUs, i get nothing. i open previous sessions that read the MIDI files and play it back fine, but when i actually try to play something in, it does not work. it's very aggravating. i am sure most of us have deadlines. so....wtf?
my setup is :
Mac Pro 2.8 GHz
Memory: 4 GB
PT 8.0.1 Digi 003 Rack
M-Audio keystation 88
it is scanning my controller no problem (obviously, otherwise reason wouldn't work at all)
  #25
Old 10-29-2009, 08:42 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
my setup is :
Mac Pro 2.8 GHz
Memory: 4 GB
ur midi channel is more than likely NOT on channel 1 in Xpand.. chk that & put it on channel 1...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
  #26
Old 10-29-2009, 11:41 AM
nope that's not it. nothing will play in my pt session except for reason
i have been working with this stuff hours on end daily for the last 5 years or so. i (hopefully) know most ways around trouble shooting and getting this to work one way or another. all i usually have to do is go into the audio/midi setup and create a new configuration. or trash my databases and preferences and restart. out of the 5 or 6 times i did this yesterday, it did work once for about 5 minutes, but then, i figured problem was solved so, shut down and took a break, then when i restarted, same problem, all night long, until i surrendered and ended up using reason
  #27
Old 10-29-2009, 05:31 PM
tunespin tunespin is offline
  #28
Old 10-29-2009, 05:42 PM
Hi all - I'm the creator of this thread if you're new to the thread.
1st of all, to answer the kind digi tech support people. I'm using the new (well I guess not quite so new) kontakt 3.0 that ships with komplete 5.
Again, everyone should note that the issue is not whether pro tools is recieving midi or not. It is when a previous temp is used where midi and instruments (any instrument i.e kontakt, reason, expand you name it) were working. However, MIDI is NOT being received when attempting to create a session from scratch.
Correct me if I'm wrong but each newly created session is a "blank slate" midi wise and should therefore receive midi no matter what UNLESS something is "fuxored".
I've always been able to create a new session, create one midi track, set the input of the midi track to whatever AMS is seeing (i.e your midi device) hit the keyboard and bingo - the track meter starts jumping.
The fact that I'm following these very same steps and the digi 002 is getting midi but the midi track in the session is not is a real head scratcher.
The most annoying part of this is that it appears random. The other day I was able to create a new session with one midi strip with no problems receiving midi. That same day I tried again and it failed.
My apologies to keeeeybeeets as I've been away from pro tools for the last 5 days (and in an imposed nuendo session...yes...feel my pain) so I've been unable to send him a "funky" session in which to try on his rig to see if results vary.
cheers y'all - let's keep tryin to figure this out!
  #29
Old 10-29-2009, 06:16 PM
You need to remove those incompatible plug-ins, or update them.
The are almost certainly a contributor to the problem - long story short, they can corrupt sessions or cause very intermittent and bizarre behavior, exactly like you're seeing.
If you can use the tech support utility to generate and post a plug-in version list I can help with identifying the problematic ones. You can always refer to our compatibility grid here as well.
Support FAQ
  #30
Old 11-02-2009, 09:43 AM
lostinlondon lostinlondon is offline
Hi there
Here is a list of my plugins as per the version generator.
Is eveyone here running Kontact 3 ?
Mon 2 Nov 2009 17:35:29 GMT
Pro Tools Version
__________________________________________
Pro Tools LE.app
8.0.1, Copyright 1991-2009 Digidesign, A Division of Avid Technology, Inc.
Plug-In Versions
AIRChorus.dpm
1.0.1.9624 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc.
AIRDistortion.dpm
AIRDynamicDelay.dpm
AIREnhancer.dpm
AIREnsemble.dpm
AIRFilterGate.dpm
AIRFlanger.dpm
AIRFrequencyShifter.dpm
AIRFuzz-Wah.dpm
AIRKillEQ.dpm
AIRLo-Fi.dpm
AIRMulti-Chorus.dpm
AIRMulti-Delay.dpm
AIRNon-linearReverb.dpm
AIRPhaser.dpm
AIRReverb.dpm
AIRSpringReverb.dpm
AIRStereoWidth.dpm
AIRTalkbox.dpm
AIRVintageFilter.dpm
Absynth 4.dpm
4.0.5, Copyright © 2006 Native Instruments
AmpliTube1.xLE.dpm
AmpliTube 1.x LE, (R)(C) IK Multimedia 2006
Analog Factory.dpm
1.2, Copyright 2006 Arturia
BF Essential Clip Remover.dpm
8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc.
BF Essential Corr.dpm
BF Essential Meter.dpm
BF Essential Noise.dpm
BFD Lite.dpm
1.0x0, Copyright 2006 FXpansion Audio UK Ltd..
BFD Lite.plg
BFD version 1.5.0.45, Copyright 2003-2006 FXpansion Audio UK Ltd.
Boom.dpm
Chorus.dpm
Click.dpm
Cosmonaut Voice.dpm
D-Verb.dpm
DB-33.dpm
DigiReWire.dpm
8.0.1, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc.
Dither.dpm
Dynamics III.dpm
EQ III.dpm
Elastic Audio.dpm
Eleven Free.dpm
Flanger.dpm
Hybrid
Inspector.dpm
v1.1x11, Copyright 2002-2006 Elemental Audio Systems
Invert-Duplicate.dpm
JOEMEEK Compressor.dpm
JOEMEEK Meequalizer.dpm
Kontakt 3.dpm
3.5.0, Copyright © 2009 Native Instruments
Kore Player.dpm
2.0.4, Copyright © 2008, 2008 Native Instruments
LoFi.dpm
Maxim.dpm
MiniGrand.dpm
1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc.
Mod Delay II.dpm
Multi-Tap Delay.dpm
Normalize-Gain.dpm
Ozone3.dpm
3.1.1, Copyright © 2006 iZotope, Inc.
Ping-Pong Delay.dpm
RNDigital
RectiFi.dpm
Reverse-DC Removal.dpm
SansAmp PSA-1.dpm
SciFi.dpm
Signal Generator.dpm
SignalTools.dpm
Spectron.dpm
1.1.0, Copyright © 2006 iZotope, Inc.
Structure.dpm
1.0.2.7584 Copyright 2008 Digidesign, A Division of Avid Technology, Inc.
TL AutoPan.dpm
TL InTune.dpm
TL MasterMeter.dpm
TL Metro.dpm
Time Comp-Exp-Pitch Shift.dpm
Time Shift.dpm
8.0.1, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved.
TimeAdjuster.dpm
TimewARP_RTAS_Lite.dpm
1.0x0, Copyright 2003-2006 Way Out Ware, Inc.
Trash.dpm
Trim.dpm
Vacuum.dpm
VariFi.dpm
Vinyl.dpm
1.7.3, Copyright © 2006 iZotope, Inc.
WaveShell-DAE 6.0.6 (Automap).dpm
1.0
WaveShell-DAE 6.0.6.dpma
XPand!.dpm
2.0.1.9624 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc.
bombfactory BF76.dpm
Plug-Ins Unused Versions
BF Essential Clip Remover.dpma
7.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
BF Essential Corr.dpma
BF Essential Meter.dpma
BF Essential Noise.dpma
BF Essential Tuner.dpm
BF Essential Tuner.dpma
7.4, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Broadband Noise Reduction LE.dpm
Chorus.dpma
Click.dpma
D-Verb.dpma
DigiReWire.dpma
Dither.dpma
Dynamics II.dpm
Dynamics III.dpma
EQ II.dpm
EQ III.dpma
Elastic Audio.dpma
Funk Logic Masterer.dpm
Funk Logic Masterer.dpma
Hybrid.dpm
1.0.1.1590 Copyright 2005 Digidesign, A Division of Avid Technology, Inc.
Invert-Duplicate.dpma
SoundReplacer.dpm
Synchronic
1.0, Copyright 2004 Digidesign, A Division of Avid Technology, Inc.
TL Space Native.dpm
8.0.0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Trim.dpma
VocALignLE.dpm
2.9.6, Copyright 1995-2007 SynchroArts Ltd.
Xpand!.dpma
1.0.1.989UB Copyright 2005 Digidesign, A Division of Avid Technology, Inc.
moogerfooger AD.dpm
Toolkits and Digitranslator Versions
Music Production Toolkit is not installed
DV Toolkit 2 is not installed
Digitranslator 2 is not installed
Digitranslator 1 is not installed
Complete Production Toolkit is not installed
Can't receive MIDI in Pro Tools 8. SteveWitt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 01-21-2011 11:12 AM
Can Pro Tools receive Real Time Tap Tempo Midi Information from an External Device? l0d015 Pro Tools TDM Systems (Mac) 8 08-23-2010 10:21 PM
Pro Tools LE 8.03 + Digi 002 cant receive MIDI MikeLip MIDI 5 03-11-2010 07:41 PM
Can Pro Tools receive Real Time Tap Tempo Midi Information from an external device? l0d015 MIDI 3 09-30-2009 11:46 AM
How Do I Configure PT to receive MIDI? fooloof Pro Tools M-Powered (Mac) 0 02-14-2007 02:23 AM
