Old 10-22-2009, 01:56 AM
tunespin tunespin is offline
Default Re: Pro tools 8 LE unable to receive midi
you know, I think it may have happened even before the 8.0.1 update - and out of nowhere it seems.
actually yes...it started before the update. my gf had brought over her keyboard, it didnt work and i dismissed it as "the keyboard being effed". but then of course I opened AMS prefs and voila - test midi received.
so strange that both Logic 8 and AMS would receive midi but not pro tools - especially strange is that the midi that ams and logic are receiving is being PIPED IN VIA THE DIGI 02!
Old 10-22-2009, 02:38 AM
ankely ankely is offline
Cool Re: Pro tools 8 LE unable to receive midi
I've seen this problem before...
Follow these paths:
Setup>MIDI>Input Filter...
Make sure that "Notes" is not checked
(See Chapter20: MIDI Recording pg. 391 of the Pro Tools Reference Guide for more information).
Setup>MIDI>Input Devices...
Be sure your device is checked.
(See Chapter20: MIDI Recording pg. 390 of the Pro Tools Reference Guide for more information).
Hope this helps.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2.
It is what it is...
ScrewMakerMusic
Old 10-22-2009, 10:16 PM
thanks for the response!
unfortunately those settings are already correct in my case.
also, isn't creating a brand new session just like a blank slate? would pro tools hang on to those setup prefs when creating from scratch? since I've never disabled midi data or my midi devices via setup, it doesn't seem like that could be the issue in my case.
someone in this thread will likely solve their issue via setup > midi.
cheers all.
Old 10-22-2009, 10:20 PM
I'll send you one of mine - what's you addy?
music or post?
AL
Old 10-22-2009, 10:28 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Is it all VI's that do this or certain ones?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
  #16
Old 10-23-2009, 08:23 AM
cetanorak cetanorak is offline
VI as in virtual instrument?? Doesn't matter which instrument is loaded, not even receiving MIDI signal input to the instrument or MIDI channel.
  #17
Old 10-23-2009, 08:34 AM
I'd almost have to see it to tell u then... If u have Midi thru check, thatz almost all that is needed... I know TUNESPIN suggested this, so of course u do so as well TS, but u guys can shoot me the session files with the VI's on it & I'll see what I can see
put it in DROPBOX.YOUSENDIT.COM/LOSTSTUDIO
Just copy & paste that link & I'd only need the session file itself not the folder...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
  #18
Old 10-23-2009, 04:44 PM
Anybody from Digidesign have any further suggestions so that MIDI can be used in Pro Tools version 8.0.1?
  #19
Old 10-23-2009, 04:51 PM
We're ur best bet man but if u don't want our help thatz kool too... I'm I'm using a ton of it on a session rite now on .1 (Garritan/Structure/Reason/Vienna/Stylus & Trilogy) with my Triton & my Axiom...but heyyy, what do I know...I tried...I'm out
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
  #20
Old 10-24-2009, 09:36 PM
Hey dude,
I'll send you my session and perhaps you can see what's up.
cheers,
AL
Can't receive MIDI in Pro Tools 8. SteveWitt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 01-21-2011 11:12 AM
Can Pro Tools receive Real Time Tap Tempo Midi Information from an External Device? l0d015 Pro Tools TDM Systems (Mac) 8 08-23-2010 10:21 PM
Pro Tools LE 8.03 + Digi 002 cant receive MIDI MikeLip MIDI 5 03-11-2010 07:41 PM
Can Pro Tools receive Real Time Tap Tempo Midi Information from an external device? l0d015 MIDI 3 09-30-2009 11:46 AM
How Do I Configure PT to receive MIDI? fooloof Pro Tools M-Powered (Mac) 0 02-14-2007 02:23 AM
