Weird graphics problem on mixer window
The mixer window gets progressively more and more distorted with vertical lines that are clearly sometype of ghosting or something. It makes portions of the window unreadable. It always starts on the left side of the screen. Adding sends and plugins only makes it worse.
Anyone else? Dual 2.5 G5 1.5 Gig RAM 7.1cs10 HD3 2 192 I/Os D-command Thanks Mike |
Re: Weird graphics problem on mixer window
I had a bizarre display about a week ago.
On one track that I was trying to apply AS to, all of a sudden displayed all the regions of the session in the track. I have a couple of screen shots for anyone interested. PT7.2cs1 |
I've seen a weird redraw issue on one rig where the top 25% of the waveform will offset to the left - it'll affect all the regions on a track. I also have a screenshot.
PT 7.2cs1, 2.7MHz G5, 3.5G ram, 2x192, expansion chassis HD, 1 core card, 2x accel |
One thing I have noticed is that it happened this time on a sessin that was brought to me for mixing which was started on an M-audio (PC) rig. Could be an anomoly from migration from PC (M powered PT) to Mac HD. Maybe an RTAS issue?
Is it possible that there could be some corruption somewhere that causes these things? mike |
Did you find the solution to this problem? I am having the exact experience with the ghosting vertical lines and breaking up of the mix window you referred to in your post
"Weird graphics problem on mixer window." |
I narrowed it down to sessions that were coming from clients who had LE rigs at home. I do mostly mixing (HD3 rig) and I get a lot of material from LE sources. Almost across the board, sessions that come from LE still to this day give me these problems. Very frustrating. I tried everything from importing everything into a new session to save a copy as and nothing helps. I just gave up thinking that I was alone on this. I would love to figure it out. Maybe it has something to do with the display card??
Please let me know if you find out the problem. Mike Dual 2.7Ghz PPC OSX 10.4.9 PT 7.4 (latest cs update) HD3 cards in the mac |
Oh, I forgot to mention this...
Closing the mixer window and then opening it again will get rid of the graphics display problem, but as soon as you scroll left or right, the lines start to appear again as if it were a virus that got worse and worse. Mike |
Mix window
Mike,
Thank you for responding. I am having the exact same issues, even the scrolling back and forth. I posted the question on the General Discussion Forum and two gentlemen albee1952 and 77pro suggested I try; " trash preferences,reseat the video card, try a different cable to the monitor(cheap VGA cables can screw with the signal) If you have an extension on your VGA cable, remove it for testing Seriously, this sounds to me like a video problem and not a protools problem but you never know....." Mike, have you tried any of the things mentioned above? I think between the help/suggestions from the serious heavy weights on here, and the two of us, we can narrow this problem down and get our mix windows back. JAH Dual 2 GHz PowerPC G5 HD2 Accel 96 I/O Version 6.9.2 |
Mike,
Great news! I re-seated the video card as was suggested by albee and pro and the ghost has left the machine! I hope your issue will be solved by re-seating the video card as well! ProTools HD2 Accel Version 6.9.2 96I/O Dual 2 GHz G5 Radeon 9600Pro |
I'll try reseating the video card. It still baffles me and defies logic that the mixer window is perfect when sessions are HD from the start, and only messes up when sessions come to me that started out as LE sessions. But hey, whatever works. I will definitely try everything you mentioned.
Thanks!! Mike |
Weird problem with a 002 Mixer - keeps switching to Mono during sessions | Sonic_Techniques | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-24-2011 04:23 PM |
Weird graphics in PT 8 | zeeman | Pro Tools TDM Systems (Mac) | 0 | 01-07-2009 12:43 PM |
Weird graphics with .png appearing in menu | crizdee | Pro Tools TDM Systems (Mac) | 9 | 07-29-2008 07:41 PM |
Weird audition problem in import audio window | mr.armadillo | Tips & Tricks | 6 | 08-09-2007 02:10 AM |
weird graphics bug in 7.1?!? | MrJakie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-09-2006 01:28 PM |
