Old 04-01-2002, 07:05 AM
rlcowa@work2 rlcowa@work2 is offline
Default Reorder plugin list?
Is there a way to reorder the AS and RTAS plugin lists? I'd like the ones I use most to be on top and the rest be in alphanumberic sequence. Can this be done? Thanks. RC
The DUC rules!
Old 04-01-2002, 07:14 AM
Mark_Knecht Mark_Knecht is offline
Default Re: Reorder plugin list?
Not that I've ever heard of. Another often requested feature has been the addition of folders for plugins. Waves folder, Digi folder, Bomb factory folder. You could then have a favorites folder where you kept the ones you use most...
Cheers,
Mark
Old 04-01-2002, 09:41 AM
homerg homerg is offline
I've never done this myself, but why don't you try renaming your Plug-ins so that the ones you like have an A or B in the beginning. Like, Compression changed to A-Compression, or D-Verb changed to B-D-Verb, or C-Limiter, and so on. Just a thought. I suspect that as long as the extension is the same that ProTools will recognize it.
ASUS A7N8X-E Deluxe
MD Athlon XP3200+2.20GHZ
Corsair XMS PC3200 400MHZ 1GB
WD EIDE 10GB
WD EIDE 250GB
XP Pro SP1
ProTools LE 6.4
Old 04-01-2002, 09:52 AM
Pako Pako is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by homerg:
I've never done this myself, but why don't you try renaming your Plug-ins so that the ones you like have an A or B in the beginning. Like, Compression changed to A-Compression, or D-Verb changed to B-D-Verb, or C-Limiter, and so on. Just a thought. I suspect that as long as the extension is the same that ProTools will recognize it.<HR></BLOCKQUOTE>
That might work, but it appears to list the plugins in the order that they were installed...not by alpha-numaric.
|OS 10.2.8|80gb ATA100|120gb ATA100|
|Mac|FW800|DP 1.25ghz|1.5gb Ram|
|PTLE 6.1.2|Digi002r|Digimax|
|Recent PC to Mac convert|
Reorder memory locations pete m Pro Tools 9 5 09-18-2011 09:53 PM
Plugin list? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-20-2010 08:03 AM
TL Space Plugin - Not in plugin list? joe.cavers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-31-2008 02:35 PM
Plugin List ESR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-15-2005 10:58 PM
6.4 Plugin List...can it be edited? whtrabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-20-2004 09:40 AM
