Old 11-17-2020, 12:52 PM
Default Re: Big Sur & Protools 2020.11
Originally Posted by Wolfgang Eller View Post
OK, finally I got the information from iLok that Avid revoked my license.
Not funny...
Not cool at all. Wonder why?
Old 12-21-2020, 09:59 AM
scottmckay scottmckay is offline
Originally Posted by Obsidian Dragon View Post
Nevertheless I did it for the sake of this community.
Thank you for your sacrifice.
Any performance difference? Or was this the end of the experiment?
Old 12-21-2020, 05:12 PM
Performance was about the same. Keep in mind that this is on a 12" Macbook, the one with the Mobile Core M5 processor running at 1.1 Ghz and only 8 GB of RAM. This is below the minimum recommended hardware requirements. This experiment was just a proof or concept and I'll leave it to other to test with adequate hardware. We're hearing pretty good Protools performance with the new M1 processors and Big Sur running on Rosetta 2 emulation.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 12-22-2020, 03:03 PM
_JJ_ _JJ_ is offline
Running 2020.12 on Big Sur here because, well, got a new MBPro (Intel 2019) and I'm not doing anything taxing, or critical.
I'll confirm Darryl's "half type in new track naming dialog box" GUI glitch, but funnily enough that only happens in Classic mode. Looks ok in Dark mode.
Also, "import audio" only shows the lower 1/2 of that window. It took me a moment to realize I had to drag down one of the bottom corners to make the search path portion of the window visible.
Other than that it seems to be running fine - for my minimal needs.
Old 12-22-2020, 06:40 PM
You should be able to backdate to OSX 10.15.x
Old 12-22-2020, 08:34 PM
Yes thanks, I know this machine will run Catalina and I have installers and even a Time Machine backup of the previous machine. But I'm not having any serious problems so I'm just plowing ahead. If I crash land then I'll backtrack.
Old 04-14-2021, 01:10 PM
Rectifried Rectifried is offline
Is it faster on Big Sur intel?.. this pinned cores/ 100% cpu flashing red thing w minimal tracks is getting tiresome
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
Old 04-14-2021, 03:02 PM
Ben Jenssen's Avatar
I was going to suggest; have you tried the "disable a core or two"-thing. But of course that was way back, that you could manage cores in PT playback settings.
I'm just trying out "turbo boost" disabling to perhaps fine tune performance, although I have no actual problem with it. Seems like I can have better stability at smaller HW buffer sizes w/Turboboost disabled, but I'm still investigating.
Old 04-14-2021, 03:43 PM
on my MBP i had the turbo switcher... and thought it worked ok... still was not 100%... on the TCan 12 core 2021 64 gig ram.. I dont know this is a LOT of power.. I dont think the turbo is there.. but honestly at this LATE stage it should be SOLID... and no Im not ferritting out plugins etc.. they work w all other daws..and given PTs record of DRagging their feet for the slim-est of improvements...
such as
lower buffer works better now
why?
they are selling a hardware native system carbon
could they have done this say Year[s] ago?
probably
case rests
Old 04-17-2021, 10:04 AM
Out of curiosity, does Protools 2021.3.1 work better on Big Sur for your processor usage issue?
Obsidian Dragon
ProTools 2020.11 Akiz Pro Tools 2020 199 12-11-2020 03:36 PM
ProTools 2020 HUI support courtsong Pro Tools 2020 2 10-02-2020 02:26 PM
