Old 11-26-2015, 09:16 PM
Vercingetorix Vercingetorix is offline
Default The Current playback Engine....
Hello guys,
I have run into a problem after I try and start a new Project where ProTools informs me that "The current Playback engine does not support a sample rate of 48kHz". And I really don't know what to do?
I haven't used ProTools in a "long" time or played guitar much at all - I have been focused on the martial arts side of my life and just now getting back into a little bit. So I'm stuck and have no idea what to do?
The only thing I did try was setting the sample rate of the new "session" to 44.1kHz but that didn't work.
Any help would be greatly appreciated
You're validating my inherent mistrust of strangers.
Schecter Hellraiser 7 Diamond - Ibanez RG7620
Eleven Rack w/ ERXP
Old 11-26-2015, 10:24 PM
Craig F Craig F is offline
Default Re: The Current playback Engine....
don't let your computer use the 11R for general audio
Thank you,
Craig
Old 11-26-2015, 10:27 PM
Top Jimmy's Avatar
It sounds like you are using your interface as the default Windows audio device. Go into your sound settings and change your playback and recording devices back to the internal jacks instead. This should solve your conflict.
James Cadwallader
Old 11-27-2015, 11:04 AM
Hmmm, I never set the interface as the default audio device. But the drivers might have hijacked it and set it up that way . The sound on the computer plays back just fine through the normal speakers without the Eleven Rack connected.
Thanks heaps.
EDIT: I looked at the audio device section before running protools and it was using the speakers and was no listing of the Eleven Rack, after turning the Eleven rack it appeared and hijacked the audio
So, I did as you suggested and set the speakers as default even with 24 bit/48kHz and everything seems hunky dory.
Thanks so much .
Eleven Rack w/ ERXP
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
Can't initialize current playback engine PT 9.03 LE mzkguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-12-2011 06:31 PM
Current playback engine... Gonk Pro Tools M-Powered (Win) 0 04-28-2010 01:55 PM
Current Playback Engine icenet Pro Tools TDM Systems (Mac) 3 09-04-2006 06:34 PM
