CPU Meter Spiking
Hello All,
Has anyone else ever had this problem? Sessions that were running fine before now won't. I get running out of CPU error. I notice when I look at the CPU meter I see a thin green line in front spiking and going into the red. Even when nothing is running . could if be a corut file??? I had this problem before (it happened after updating OS9.1 to 9.2 and updating the firmware) and I did fix it by erasing my system hard drive and doing a new install Back to OS 9.1. I would hate to have to go though that again.. Any ideals on what this could be ? I don't beleive there is anything running in the background I use this machine for pro tools only. Thanks Mac G4 466 w/ 1ghz sonnet upgrade 1.28 gig ram (260pt/ 200dae)
www.ftrmusic.com |
Re: CPU Meter Spiking
man, i just had the same damn thing happen, except that i didn't change a thing! The only thing that changed was that I moved my machine, and now i can't even playback two tracks without the thing peaking out... in the exact same fashion that you described. Anyone, please help!
tim
-- kick it, at least it makes you feel better -- |
Are all your plug in files closed under your DAE? Sometimes when I have all my plugins displayed on my system drive, it seems like it taxes the cpu, at least it does on my G4 800. But when I close them all, the meter is no longer pegged in the red.
I have a G4/466Mhz (Digital Audio) w/Sonnet 1Ghz upgrade.
I constantly have a problem with my PCI Usage meter pegging to red when I open sessions. I'm starting to wonder if I made the right choice by upgrading my CPU. [img]images/icons/mad.gif[/img] |
I had this with the cpu and also the system meter around 2 years ago, seemed that it happened to some of the early 733 quicksilvers.
I fixed it with a strip down of extensions, really weeding out the extensions from the base set and making a audio set. this fixed my prob. hope this helps. AJ
A Gentleman is one who can play the bagpipes, yet chooses not to. |
CPU spiking 11.1.1 | wesm | Pro Tools 11 | 8 | 01-07-2014 05:58 PM |
Volume meter spiking to yellow, not recording anything | Drecan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-25-2010 05:26 AM |
Cpu spiking | cmotard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-15-2010 08:17 AM |
PT8 CPU spiking demand | onepercentfree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-12-2009 10:23 AM |
System Usage CPU meter randomly spiking? | PatrickJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-28-2007 12:12 AM |
