Re: Well Here We Go. Not So Good. SOLVED
I have used the PT Prefs Helper. Repaired Permissions.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 Last edited by philip888; 05-18-2016 at 09:36 AM. |
Umount all the disks, trash the prefs.
Then 1) try creating a session just using the internal drive and all the other drives unmounted. (you won't run this way, strictly a trouble shooting technique I use as I sometimes run with 8 drives and need to find which one is failing).... Then 2) Bring one of other drives up and try again.
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Sorry if this was mentioned... Kill the video engine (don't use it) in prefs. And see if that helps.
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. |
Windows has the video engine off by default. So I just looked in prefs and see this is enabled. Will try now. Thanks.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 Last edited by philip888; 05-19-2016 at 01:54 PM. |
Thanks but this changed nothing.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
#16
When you have activity monitor opened. You load a new session. And you hit play it immediately goes to 9073? If so, what happens in your pro tools activity window? You can use QuickTime to take a a quick screen grab movie. Is this a cheese grater like mine or the newer trash can body?
#17
Specs. Processor: 2 x 2.4 GHz Quad-Core Intel Xeon Memory: 12GB 1066 MHz DDR3 ECC Graphics: ATI Radeon HD 5770 1024 MB Hard Drives: 3 x WD Caviar Black 1 TB OSX 10.10.5
#18
I copied the session from my Pro Tools Session Drive to my Macintosh HD System Drive Desktop. Open Pro Tools ran the session with no Problems.... YES... I am not CRAZY I AM NOT CRAZY>>>>>>>>> So does this mean this WD Caviar BLACK 1 TB hard drive is bad? Could there be a setting in the BIOS that is not allowing the data to transfer from one drive to the other fast? Thank you.
#19
No bios, on Mac
#20
Right PC slip.
I mean some configuration setting that would hinder or allow for faster transfer of data between drive. Not RAID.
DAE error -13001 while starting PTLE7.4 - SOLVED | winampdevil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-28-2012 08:00 PM |
SOLVED issue with 9073 error on scrub | studiojimi | Pro Tools TDM Systems (Mac) | 0 | 07-02-2012 09:56 AM |
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
I Finally Solved my -9073 Error | Thirsch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-11-2010 02:44 PM |
DAE error -9073 during playback. | Protools Newbie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-25-2007 07:21 PM |
