Old 11-11-2014, 05:53 AM
kava kava is offline
Default Re: Strange Bug - drag audio to track
same here.
trashed databases and prefs. problem still there and VERY annoying. happens when dragging from finder and snapper.
Old 11-11-2014, 09:11 AM
...re-importing everything (every track) to a new session solved the problem...
Old 11-15-2014, 06:09 PM
jwolford jwolford is offline
Trashing prefs fixed my problem for a bit. But the issue has returned. Presently I can drag the selected area of a waveform from the Audiofinder app, but not entire files. If I drag an entire file into PT from AF for the Finder itself, it gets hung up on building the waveform, I have to cancel the selected tasks before importing anything else.
Old 11-18-2014, 11:15 PM
gwhatley's Avatar
gwhatley gwhatley is offline
Great catch - if it happens again over here, I'll check the task manager to see if anything similar is happening.
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
Old 12-11-2014, 04:57 PM
Just wanted to post that this issue keeps recurring for me. My temp fix is to:
Use PT Prefs to back up all prefs, then trash all prefs
Launch Pro Tools, verify that importing works
Quit Pro Tools
Launch PT Prefs and RESTORE my backed up prefs
Relaunch Pro Tools, my prefs are back where I want them and importing files no longer results in hanging tasks with unknown errors.
If anyone has suggestions on how to drill down on this, I am all ears. But this herky jerky workaround is doing it for now.
  #16
Old 06-29-2015, 10:55 PM
bear0328 bear0328 is offline
yes,I have the same issue.
PT version:11.3.1
OS version:10.8.5
  #17
Old 05-13-2016, 06:48 PM
gwhatley's Avatar
See this ideascale bug for a possible solution:
http://protools.ideascale.com/a/dtd/...a-tab-comments
I noticed when doing a different kind of audio import using Pro Tools' Field Recorder Workflow, that I would get assertion errors if I had not done a "Clear Find" in the Clips Bin.
I don't use the Workspace anymore (deleted those catalogs in favor of SoundMiner HD+), so not sure if this helps here, but it reminded me of this thread.
Garrard Whatley
Seismic Post Audio
IMDb credits
  #18
Old 06-01-2016, 09:40 AM
dbcsound dbcsound is offline
we've been having similar issues with one rig. Dragging from a SFX network drive that is read only. When a file is dragged on to the timeline from the workspace, it looks like it is about to place then turns into a completely different file. Usually the same file until I close and restart then it may be a different file. then after trashing pref and the usual hoops to try and get it back I noticed that if I turned off the automatically copy files on import. the problem would go away. Also weird was in a completely different session dragging some files without unique id's wouldn't copy to the sessions audio files folder even with the automatically copy on import pref selected. anyone with a solution for this?
I also read on the avid site that " The behavior was further modified in v10.3.6.
During import, if a file's Unique Identifier (UID) and Date Modified are the same but the name is different, the existing file in the session is automatically used. "
Is this still true in 12? it's from this page.
http://avid.force.com/pkb/articles/e...ng/PTSW-163654
PT11, Command Drag Volume Level in audio track Paul B. Pro Tools 11 8 04-02-2014 09:59 PM
strange message when trying to commit to an elastic audio track gibsy General Discussion 2 12-19-2013 03:07 AM
Drag and copy regions to a different track? Super Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-05-2012 07:06 AM
Drag from region list onto one track Moviesound Post - Surround - Video 1 06-25-2012 08:41 AM
Audio Track Import? Strange looking captainpat Pro Tools M-Powered (Win) 1 11-27-2006 06:41 AM
