*not* use the headphone outputs on the Carbon, and use my MacBookPro instead?
Hi Carbon users.... considering getting a Carbon....
If the Carbon is some distance from me (say 20 feet) and I'm on my MacBookPro.... would it be easy to monitor stereo audio from ProTools to the MacBookPro (ideally an Apogee Groove into a USB port on the macBookPro... or even just the 1/8" headphone out on the MacBookPro).... and thus not touch the Carbon at all as it is 20+ feet away? In other words can i *not* use the headphone outputs on the Carbon, and use my MacBookPro instead to monitor ProTools? thanks. |
Re: *not* use the headphone outputs on the Carbon, and use my MacBookPro instead?
Pro Tools only uses 1 audio device for input and output. Can't split that up.
You can run an output (line level or digital) from the Carbon to another device nearer to you.
I would just add a headphone extension cable. Why buy a unit with really good headphone amps and then not use them I'm also not following on why you would park the unit 20' away when most functions are done on the front panel(aren't they?)
Avid have said that future updates (most likely paid for updates I bet) would include Eucon enabling for Carbon. There are some that have mentioned fan noise. If that’s the reason for keeping it 20’ away, well it really isn’t necessary. I have to have my ear right up against the unit to hear anything at all. I was concerned when I first got it because I expected a LITTLE fan noise. I even put a tissue up to the vents to see them move just to be sure. Apparently there have been a few units with some fan noise, but I think they have been rare.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob Squaw Creek Road Studio Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1) | M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) | 3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 | Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X | |
no, nothing to do with fan noise. it is a long explanation - i wont bore you with the details. I'd rather just focus on my original question. so it sounds like it *isn't* possible to use the headphone out on my MacBookPro to monitor ProTools when using Carbon? based on the one post above..... thanks for any info about my question. |
You can probably create an Aggregate device. I don’t have an AVB interface so don’t know for sure how it presents itself to macOS. If it appears as a Core Audio interface, then you should be able to aggregate it with the inbuilt Mac soundcard.
If it’s purely for monitoring, it shouldn’t pose any issue and would be the easiest way IMO to achieve what you’re after. Sent from my iPhone using Tapatalk |
Aggregate device means DSP/Hybrid is gone.
Is that right?
Didn’t know that. Interesting to know. Sent from my iPhone using Tapatalk |
Given the dearth of info about your system and situation, pretty hard to answer definitively. Like is your laptop the computer that PT is running on ? Or are you wanting to use it as a peripheral/second output device to monitor from ? While Carbons dual audio midi and sound instance ability allows the use of other audio source inputs while PT is open even with Ultimate... I do not know if you can do specifically what you are talking about but I am guessing an HP extension cable is the simplest solution
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
one computer. The (rare) situation is that I want to adjust headphone volume on laptop, and have the PT stereo audio come out the MacBookPro headphone output that is all. No - a headphone extension cable isn't great. I dont want to run back and forth to adjust headphone output. yes of course i could simply make a send in PT to my headphone output (on Carbon) and adjust there in PT... but that is separate from my question: with a Carbon, can there also be an audio output from my MacBookPro headphone out? thanks. |
MacBookPro&ProTools - 96k w/Headphone Jack | Tom Polce | macOS | 2 | 10-09-2023 06:09 AM |
C|24 - Headphone Mix - Cue Outputs | derbymusic | ICON & C|24 | 5 | 10-31-2012 05:45 PM |
Mbox3 outputs to an external Headphone Amp? | woodrow886 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-26-2012 02:05 PM |
outputs/headphone mix | antwellington1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-20-2007 01:59 PM |
Adat bridge for headphone mix outputs | Cecil Sweet | Pro Tools TDM Systems (Mac) | 2 | 09-10-2002 12:40 AM |
