Old 05-25-2002, 03:44 PM
speedyk5 speedyk5 is offline
Default AES/EBU sync problem
Hi
My problem is when i transfer audio from my DAT to Protools via AES/EBU there are a few clicks.Any
suggestion to avoid this? I use G4 733 with Mix3
Prism and 888 interfaces.
Thanks in advance
Kostas
Old 05-25-2002, 03:59 PM
Boom Chic Boom Chic is offline
Default Re: AES/EBU sync problem
Are your sample rates the same on your DAT as your PT session? 44.1 or 48khz? Same bit depth?
Are you using inputs 1 & 2 on the 888?
Are inputs 1 & 2 set for digital in the hardware setup-options, and is AES/EBU your digital format in the hardware setup?
Karen Basset
Boom Chic Studios
Los Angeles, CA 90048
[email protected]
http://www.boomchic.com
Old 05-25-2002, 04:54 PM
Mullholland Mullholland is offline
Karen , what do you mean with
"are you using inputs 1 and 2 "
Is there a difference between 1 and 2 and the others ?
Old 05-25-2002, 09:38 PM
Yes there is a difference. On the 888/24 (which is what i have)clock is derived from the inputs 1 & 2 when you're going AES/EBU in.
I made this mistake once, and you need to have the digital connection at least starting with 1 and 2 inputs on the 888. [img]images/icons/smile.gif[/img]
I believe that is why you are able to select what digital signal is coming into 1 and 2 on the hardware setup dialog box. Then you have to click "options" and select "digital" on the chanels you've got receiving AES/EBU
Karen Basset
Boom Chic Studios
[email protected]
Old 05-26-2002, 03:29 AM
Mark Haliday Mark Haliday is offline
It can be added however that AES/EBU inputs 3-4, 5-6, 7-8 are perfectly usable but only if the source is slaved through it's word clock input to the same master clock as protools.
Old 05-26-2002, 03:32 AM
Thanks Karen
I have the same problem with my eventides connected via AES/EBU with the 888.That means that i need to connect them always to 888's 1-2
channel?
Kostas
Old 05-27-2002, 12:08 AM
I believe that's the case speedyk5. You have to designate one as slave and one as master. PT can derive it's clock (44.1 or 48khz) from your digital gear, or your gear (depending on your gear)can be slaved to the AES/EBU clock from PT.
I had this same problem with my guitar pod connected via AES/EBU, and I had to sort all this out, but once it's configured properly, it works.
Connect your digital devices to inpputs 1 & 2 of the 888, and select your setups accordingly in the hardware setup dialog.
Karen Basset
Boom Chic Studios
[email protected]
Sync problem (MTC) rfmusic Pro Tools TDM Systems (Mac) 1 09-28-2012 04:52 AM
SYNC I/O Problem dreeves Pro Tools TDM Systems (Mac) 4 08-08-2007 09:56 AM
sync problem winnicki 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-26-2007 11:01 PM
VS-880 sync problem ShivaTribe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-18-2002 08:00 PM
sync problem jef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-07-2001 05:29 AM
