Any way to get more than 256 MIDI tracks?
Hey guys,
Is there a workaround or any solution for the 256 MIDI track limitation? Setting up MIDI templates can often involve well over 256 tracks. They likely wouldn't all be used simultaneously, but they all need to be in the session. Thanks, Mike |
Re: Any way to get more than 256 MIDI tracks?
If you are on HD then you should have your extra 128 Instrument Tracks to use.
AKA - EvilElfHobo Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4 Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified. Multi-Platinum Pro Tools Videos |
Thanks...is there any way to have the instrument tracks use MIDI outputs? I/O is audio on a instrument track. These setups typically use external sounds a la gigastudio, kontakt, play, etc. etc. though obviously some of this could be done on the same machine via VIs on an instrument track.
This seems like kind of a lame limitation on an HD system. Logic, Cubase, DP, etc. all do way more MIDI tracks... Thanks! Mike |
Yes you can, it's just the marriage of a MIDI and an AUX. If you show the "Instrument" component in your mix or edit window that were you would assign your MIDI outs. Glad I could be of help.
On a side note all the above mentioned DAWS were first sequencers before audio, we didn't get Instrument Tracks until PT 7. It was very much made as an audio editor.
Ah! Never used the Instrument component on the edit window, didn't know I could do that! Thanks!
I know PT is audio first, and am THRILLED they're catching up on the MIDI front, but we can't ever be satisfied, can we? haha...seriously, would love to see them up the MIDI count to 512 or something...in the meantime, that instrument track thing should help a lot! Thanks! Mike |
Oh, one quick thought...does using instrument tracks take up voices on the HD cards? Seems like they would...so if I have 128 instrument tracks, I'm only left with 64 (or whatever) voices left for audio tracks, plugins, etc?
Is that right? I'm always confused about the voice usage... Thanks! Mike |
Bud-deeeeee
Could you,or do u mind telling us what In the world do you need that many midi tracks for in 1 song?
You would need five separate Orchestra yet you will still have spare MIDI track left!
TiPo Pro-Tools 10.3.10 HD 2 Accel PCIe OSX 10.10.3 |
Spare is puttin it mildly...
MIDI Tracks Versus Instrument Tracks. VERY Confused. | Rick540 | MIDI | 8 | 12-04-2008 11:04 AM |
Midi Tracks - how do I record enable mutliple midi tracks? | ram1500 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-22-2007 04:32 AM |
Set up midi tracks and playing back midi tracks | RUNDMOD4MUSIC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-04-2005 03:22 AM |
Bouncing Midi Tracks to Audio Tracks ...Latency? | kirk95 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-27-2004 06:54 AM |
Would the Line 6 POD pro SPDIF outs make the guit. tracks MIDI tracks? | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-06-2000 08:40 AM |
