Autotune EVo made protools crashed
i don't know which part cause this problem, autotune itself? the compitable between autotune and protools?
i was installed autotune evo yesterday, and i started to use it today for vocal tuning, but i found it's not solid enough, it made protools crashed when i using the graphic mode, i modified something then playback and modified again then playback,and repeat countinously. when i do like this, AT always made PT crashed. especially when i use the tool with a waveform icon. i was trying to remove the pref but it won't change. my Mac : Mac Pro/ osx 10.5.6 / protools hd3 7.4.2 |
Re: Autotune EVo made protools crashed
TDM or RTAS? I have had crashes with RTAS versions! Do you have any crash logs? Chris
Same here with Evo RTAS.
Since AT5 I'm having lots of crashes when editing in graphic. This force me to save the session every single correction. This morning was a nightmare, 4 crashes !!!
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
No problem, just use TDM which sounds better anyway. Zero crashes here with AT 6.0.6 TDM
it is TDM version
I reported and send a crash log to Antares! and they have been very responsive and would be interested in any information and crash logs. so if you can send details and crash logs to Antares support. info @ antares .com Chris
it's done
same problem here. The crash does always happen when using the undo (control+z) function.
hi.
Auto-Tune Evo RTAS6.06 crash! main thread 0x0 |
Could someone confirm this:
I think I'm very sure about saying that as soon as you change the default buffer size from 240 to let's say 400 AT will crash ProTools sooner or later. I worked with AutoTune now for 4 days straight and everytime I made the buffer bigger AT will crash. |
Saved, then Protools crashed, can't find the session any more | ohlone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-25-2011 05:50 PM |
ProTools Crashed on Bounce with Ableton | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-03-2011 06:37 PM |
ProTools crashed, now none of my sessions play! | daleh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-06-2006 09:34 PM |
New autotune 4.23 crashed my system in graphic mo | francois | Pro Tools TDM Systems (Mac) | 2 | 02-10-2005 12:48 PM |
Protools crashed -Can't open- No Problem ! | Cliffy_Boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-13-2003 05:09 AM |
