Old 03-24-2009, 11:51 AM
BookSix BookSix is offline
Default Re: Stereo session to Surround...?
Well, if it a bug I've had it with every PTHD system I've installed in this studio since 6.x! I'm currently on 7.3.1.
If I go to IO and create a 'new path' my only options are mono and stereo (new path appears first with a '?' in the field).
Also, I only have 'stereo mixer' in the plugin's folder... And, when creating a new session, the I/O settings box does not give me surround options.
Brett Michael Wiesman
www.trackstarstudios.com
Old 03-24-2009, 02:36 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
A ha!!!! Now we are getting somewhere. This is exactly what I was expecting.
The reason you aren't seeing anything wider is the surround plugins weren't copied off the installer disc when you installed protools because you selected the "music only" setting that you mentioned.
I think the quickest and simplest fix is to put the surround plugin back into your plugin folder from your PTHD installer disc/download.
If you can't find it (or it is compressed within the installer) simply run the installer again and select the surround option.
Once you have the surround plugin in your plugins folder, you'll see all of the other available multi-channel selections.
Old 03-24-2009, 04:00 PM
LOL, nice. I was afraid it'd be that. I was able to find out big TDM box but it dates back to 6.9. idk where the 7.3 disc is. But I'll keep searching I guess... thanks
Old 03-26-2009, 11:25 AM
O.G. Killa's Avatar
You might be able to download the installer off the Digi site and get the mixer plugin out of that.
Old 03-26-2009, 11:41 AM
StudioRhythm StudioRhythm is offline
It seems strange to me that you don't have the surround mixer plugins in your unused plugin folders -- I've also always chosen stereo-only when installing PT, but I have the surround mixer plugins sitting in the unused plugins folder anyway. If you download the installer, I'm pretty sure a reinstall will solve your problem.
www.studiorhythm.com
Installer WANTED:Neyrinck SoundCode Stereo surround-to-stereo down-mixer Ale Pro Tools 10 3 08-14-2012 09:05 AM
Converting a stereo session to 5.1 surround SilentSi Pro Tools TDM Systems (Mac) 6 07-11-2011 05:00 AM
Converting from a 5.1 Surround to a Stereo session donhozz Post - Surround - Video 22 12-06-2009 06:15 AM
Bouncing to stereo in a surround session Mikelib1981 Post - Surround - Video 2 09-07-2007 11:48 AM
Surround mixer taking up three chips in a stereo session!! el biciclista Pro Tools TDM Systems (Mac) 6 03-31-2003 01:42 PM
