Old 02-13-2010, 06:58 AM
gregfrey gregfrey is offline
Default Need help converting 88,200 to 44,100
I have a bunch of .wav files that are at 88,200. I have an old PT 5 system. What's the easiest way to convert the files to 44,100? I have access to either a PC or Mac to do the conversion.
Thanks
Greg Frey
Old 02-13-2010, 07:08 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Need help converting 88,200 to 44,100
BarbaBatch from AudioEase is the "Leatherman" for all things audio. Check it out at http://www.audioease.com/Pages/Barba...rbaBatch4.html
Their SRC is some of the best around.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 02-13-2010, 07:16 AM
Good grief, that's expensive. Is that what I'm looking at to get this done?
Old 02-13-2010, 07:36 AM
necjamc necjamc is offline
You can use PT, Cool edit pro, wavelab, or any DAW. Simply import the file and bounce to disk at 44,100, or in cool edit / audition I believe you just save as.
Old 02-13-2010, 07:43 AM
clint bennett clint bennett is offline
No need to "bounce to" in PT - just export region as audio file (in the regions list menu). this will save you a ton of time as you can do them all in a batch and it will work "offline" and not in real time. just remember when it asks to select "tweakhead" as the conversion quality.
Old 02-13-2010, 07:46 AM
Yes that's right, I forgot about that. I haven't used that in a while.
Old 02-13-2010, 07:53 AM
But I can't import an 88.2k file into PT5, can I? It certainly won't play back at the right speed. Or does it not matter?
Old 02-13-2010, 08:03 AM
IN PT 5 can you not import audio and convert it on the way in? In 7.4 and 8 I can.
Old 02-13-2010, 08:08 AM
Extreme Mixing Extreme Mixing is offline
No. He'll need another application. PT5 won't work above 48k.
Steve Shepherd
Extreme Mixing
Old 02-13-2010, 08:10 AM
JFreak's Avatar
JFreak JFreak is online now
Wasn't there a PT5 for HD cards? My memory is not at its best anymore but I could swear HD started from PT5...
Janne
Converting to MP3 keytone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 02-24-2009 05:54 PM
mp3 converting HELP?!?! steve.05251 Pro Tools M-Powered (Win) 0 01-28-2009 03:58 PM
Converting from pc to mac! i need some help mr razor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-16-2008 02:09 AM
Converting 24 bit to 16 mblack Pro Tools TDM Systems (Mac) 14 04-02-2005 05:55 PM
converting from 48K with PT Grillo Pro Tools TDM Systems (Mac) 4 05-16-2000 03:53 PM
