ATTO card for G4
Hi
I'm running PT 5.1.1 on a G4 with OS 9.2.2. Up till now, I've been using firewire drives. I now want to get an internal scsi drive. Which ATTO card do I need? I have no need for external scsi devices, so I think I don't need a 'dual' card. Is that correct? Thanks Greg Frey |
Re: ATTO card for G4
I think the officially supported configurations with Pro Tools are: SCSI 64 kit and SCSI 128 kit. Both dual channel ultra wide external SCSI.
I don't know if there is a internal ATTO solution for g4. Mabye you can check ATTO site to find it. regards AJP
We always keep on trying |
The dual channel indicates that there are two discreet SCSI busses. We use an internal 36G and an external dual Glyph rack. In the case of the Atto EPCI-DC card that we use on our MDD G4, there are two external connectors and two internal connectors. I think most Atto cards have both external and internal connectors. Check the Digi compato docs for the approved drivers and setup info. SCSI still rocks!
Cheers, Chris
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
Note that once you start using OS 9 and OS X you will run into Assertion error-36, that is a driver conflict between the two operating system. Here's what you do, erace all OS9 drives and re place drives from the OS X system. make srue when you do this you check the ( add OS 9 drivers ) option or you won't be able to mount your OS 9 dirves. This is a day of busy work but one you can't afford not to do. I used a 120 gig firewire drive as a tank and did it one drive at a time, drag and drop, errace, with OS X then add OS 9 drives. , drag the files back onto the newly formated drive and more on. Atto intern and external SCSi works great on all my systems.
Later, Kurt [email protected] Intel duel Quad core PT 8.0cs3 HD4 D Command / D control |
DO NOT USE ATTO PSC CARD!!! | jumpindog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-13-2003 07:34 AM |
Which ATTO card to buy? | tooticky | Storage Subsystems | 1 | 01-21-2003 08:30 AM |
Which ATTO card? | drew24032 | Pro Tools TDM Systems (Mac) | 10 | 05-28-2002 10:13 AM |
Which ATTO card? | bruce lang | Pro Tools TDM Systems (Mac) | 7 | 01-14-2002 06:28 AM |
Besides ATTO dual card, anyone using another card reliably?? | Mt.Everest | Pro Tools TDM Systems (Mac) | 2 | 02-16-2001 02:41 PM |
