Old 09-14-2011, 08:30 PM
anackman's Avatar
anackman anackman is offline
Default Grid Lines in Slip Mode 9.0.5?
when i choose slip mode in PT 9.0.5, the grid lines disappear and only show down-beat lines (no 4ths, 8ths, 16ths, etc.). How do I make it so the grid lines remain shown even in slip mode?
in grid mode, the grid lines are there and look normal.
thanks.
-anack
____________________
specs:
PT 9.0.5
OSX Lion 7.1
MacBook Pro i7 2.66 GHz Core Duo
8 GB Ram
Old 09-15-2011, 03:47 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Grid Lines in Slip Mode 9.0.5?
They show fine here. In Slip they do seem to fade-contrast a bit but still are visible.
Try the ProTools Pref and Database Helper ( V-2.3 rc2)
PT's 9.0.5, OS 10.7.1
MP Dual 6, 12Gb, 64 bit kernnel
HD3 Magma solution
Old 09-15-2011, 07:55 AM
anackman's Avatar
is there a way to adjust the contrast of the grid lines? maybe mine are in low contrast...didn't realize that was even an option.
MAC OS Ventura
Pro Tools 2024.3
2020 iMac 27" 3.2 Ghz i5, 64GB Ram
UA Apollo Rackmount Thunderbolt + Dangerous D-Box
2x Glyph Studio 2TB Raid SSD
Old 09-15-2011, 03:24 PM
DetroitT's Avatar
From the monitor it self or the Monitor prefs in system pref (Calibrate). not in PT's other that your color depths but this doesn't effect the grid.
Viewing grid in slip mode remusjacobs macOS 2 10-15-2012 02:41 PM
Slip to Grid mode no visual grid unless pressing "grid" mgoorevich Pro Tools 9 5 11-13-2010 07:11 AM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 10:30 AM
Removing Vertical Grid Lines while in Slip Mode teacherman Tips & Tricks 3 06-08-2010 12:32 PM
Grid Lines - Slip Mode vs. Grid Mode Mt.Everest Pro Tools TDM Systems (Mac) 24 02-20-2006 08:38 AM
