Copy/Paste Plug-in data with ICON
Hi everybody, I´m new in this forum.
I need to know if somebody knows how to copy the plug-in data and paste it in another channel ussing ICON Shortcuts. I know that I can do with Shift + command + C, but a few months ago, one Avid seller show me in a conference how to do it with an ICON and I don´t remember it was Probably here I will find an answer finally . Thanks in advantage for the information... |
Re: Copy/Paste Plug-in data with ICON
esp. that pdf is very helpful:
http://akmedia.digidesign.com/suppor...mand_44749.pdf There it says: To copy the current settings of a selected plug-in simply press command shift (control shift) while pressing the Sel button on the insert whose settings you want to copy. To paste your copied settings simply press command shift (control shift) while pressing the B•M•P button on the encoder whose insert settings you want to overwrite. (The source and destination inserts must contain the same plug-in with the same channel width for this operation to work.)
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
I still wish there was a one button press alternative for these two commands in the 'soft keys' section
copy-paste clip and automation data | marcelkavka | Pro Tools 10 | 2 | 08-13-2012 04:20 AM |
Copy/Paste error with large amount of data | yoann | Pro Tools TDM Systems (Mac) | 3 | 07-27-2009 02:58 AM |
copy paste region without data? | crizdee | Pro Tools TDM Systems (Mac) | 4 | 01-18-2007 04:32 AM |
copy plugin data ,paste on another parameter ? | andre tchmil | Tips & Tricks | 2 | 01-17-2007 10:36 PM |
Copy/paste automation data: Volume to Trim Gain?? | el biciclista | Pro Tools TDM Systems (Mac) | 3 | 11-22-2006 08:50 PM |
