Copy/Paste error with large amount of data
Hello all,
I am getting a strange error when I try to copy paste a large amount of data in one of my session. It happen in a session containing about 90 tracks (83 voices and some Aux), when I try to copy paste all these tracks. The error is "Some automation parameters in the clipboard do not match the paste destination". But it doesn't make sense, because if I copy less tracks, the problem doesn't happen. It only happen I am copyng "too much" tracks (more than 30). I have try to take out each tracks one by one of the copy process, and it doesn't seem to be related to a particular track. I have some other sessions with a similar configuration, and the problem doesn't happen... If someone have an idea or already meet this kind of problem, I would be pleased to hear it ! Thanks ! Regards Yoann Protools 7.3.1 Last edited by yoann; 07-27-2009 at 01:06 AM. Reason: typing error |
Re: Copy/Paste error with large amount of data
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Only time i have seen this is when i accidently try to drop the wrong regions onto the tracks? like i mis-aligned the paste destination and tried to copy on the tracks below or above. Just check you aren't accidently doing this. Chris
In fact my problem is not exactly the same, because I am not copying data from one track to another, but from a track to the same track, in "Group All" (that why crizdee's proposition, which should work when this message prompt up, doesn't work here). So it's not the same problem, but it sound like it is similar. So I focus on EQ3, and removed each EQIII, one by one on each track and look what happen each time I removed one. And I discover that if I remove an EQIII from a 5.0 Aux track, my problem disapeared ! My problem was caused by this EQ3, which seems corrupted . So I have deleted it, then recreate the plug and its automation, and now everything is fine... Thanks Frank Kruse Yoann (and sorry for my approximate english) |
copy-paste clip and automation data | marcelkavka | Pro Tools 10 | 2 | 08-13-2012 04:20 AM |
Copy/Paste Plug-in data with ICON | tiagokaizer | ICON & C|24 | 3 | 03-08-2011 03:52 AM |
copy paste region without data? | crizdee | Pro Tools TDM Systems (Mac) | 4 | 01-18-2007 04:32 AM |
copy plugin data ,paste on another parameter ? | andre tchmil | Tips & Tricks | 2 | 01-17-2007 10:36 PM |
Copy/paste automation data: Volume to Trim Gain?? | el biciclista | Pro Tools TDM Systems (Mac) | 3 | 11-22-2006 08:50 PM |
