Old 04-19-2022, 10:16 AM
Isadore Isadore is offline
Default fades
I'm probably just a common idiot, but I can't figure out how to delete a fade in my PT 12.7.1. I enable the Smart Tool then highlight the fade area and scroll down the Edit column to "Fade" but there is no option to delete. It was so easy in older versions of PT. Alas
Bill Mize
Old 04-19-2022, 01:19 PM
Default Re: fades
With the fade area highlighted, just hit the Delete key. Keep in mind that its also easy to adjust an existing fade with the smart tool. It allows you to change the shape, lengthen or shorten, etc(might be worth watching some youtube tutorials on using fades in pro tools)
Old 04-19-2022, 03:32 PM
Default Re: fades
I actually tried that but both the fade and the track disappears.
Bill Mize
Old 04-19-2022, 03:51 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: fades
You have to only highlight the fade, nothing else. Click inside the fade.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-20-2022, 07:04 AM
Default Re: fades
got it. I click on the actual fade line and deleted it. Success!
Bill Mize
Loud White noise fades on fades and dissolves! www Pro Tools 9 2 04-16-2013 09:59 AM
Pro Tools 8.0.1 and Fades and Cross Fades Pop mikejavo Pro Tools TDM Systems (Mac) 1 11-26-2009 08:54 AM
Fades prefs vs. Batch Fades (or beating a dead horse) Starcrash Post - Surround - Video 2 09-23-2008 03:40 PM
create fades batch fades issue pt le theom Tips & Tricks 4 07-24-2006 09:46 PM
fades on muted regions render active fades?! yikes clarpark Pro Tools TDM Systems (Mac) 11 02-08-2004 04:49 PM
