Old 02-15-2018, 10:04 AM
TrentWilliams TrentWilliams is offline
Default Parallel Task Optimisation
Just found this hiding in Preferences .. not sure when they snuck it in. But probably one of the more exciting new features. It's Default is 'Off', so go change it up !
Parallel Task Optimization (Pro Tools HD Only)
The Parallel Task Optimization preference lets you select the optimal possible number of parallel processing tasks that can happen at the same time on your computer. Relevant factors include how many core processors your computer has, how fast the processors are, how fast or how fragmented your hard drives are, how fast your network storage connection is, and so on. The optimal possible number of parallel processing tasks is usually pro- portional to the number of core processors in your computer.
Affected parallel processing tasks include:
• Waveformcalculation
• Fileindexing
• RenderingClipGain,ClipEffects,andElastic Audio
Compare different settings to see what works best with your system.
Off Only a single task is processed at a time
Low Up to 4 tasks can be processed simultaneously
Med Up to 6 tasks can be processed simultaneously
High Up to 8 tasks can be processed simultaneously
When working with an Avid NEXIS network storage system, select the optimal setting for your net-work connection as follows:
Low 1 Gb Connection
Med Dual 1 Gb Connection
High 10 Gb Connection
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 01-18-2019, 04:56 PM
evanevans evanevans is offline
Default Re: Parallel Task Optimisation
Awesome!
Old 01-19-2019, 03:51 AM
bartosz idzi bartosz idzi is offline
PARALLEL TASK OPTIMISATION
Be careful with this one.
I remember changing it to ON about 2018.4-2018.7, and pro tools ultimate started crashing frequently even when doing nothing after opening the session. Removed all plugins, one by one, nothing helped. Clearing the preferences (Parallel Task Optimisation is OFF by default) helped. Then, after switching it to on even without no plugins, and PT started crashing again. Usually a couple of minutes after opening the session. Left it off since.
OS X 10.12.6 , cMac Pro 5,1.
If you work with it with recent versions of PT Ultimate and have no crashes, let us all know :)
Parallel Task Optimizations Preference? zion Pro Tools 12 18 01-19-2018 06:28 AM
PT12 Keyboard Optimisation Guide TrentWilliams Pro Tools 12 1 04-13-2017 10:04 PM
PT9 + 10 parallel on OSX? 10.6 or 10.7? janmuths macOS 5 02-06-2012 08:32 PM
PT HD view optimisation CosmicJunkie Pro Tools TDM Systems (Mac) 0 06-22-2007 04:07 AM
help - optimisation bug Steve Moore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-01-2002 09:48 PM
