"Save Session Copy In..." not working properly
Got a huge session I need to export a portion of to give an assistant of mine.
I delete all unnecessary tracks. Then I do the old shift+cmd+d (display all), shift+cmd+u (select unused), shift+cmd+b (remove). When I now choose "save session copy in" checking "Audio Files" there are files being copied, that aren't in the clip list anymore. I have to check "selected tracks" to get it done properly. Anyone else can confirm this bug? There are no hidden tracks or playlists in the session - I checked.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Re: "Save Session Copy In..." not working properly
Do this. Then save and close. Reopen, do it again, then try it.
See if that does the trick. And of course make sure you are showing Auto Created Clips before all of this, but I'm sure you're doing that already. |
That does work.
Still it's a bug that should be fixed. However, the "selected tracks only"-feature is neat, too. Guess I'll be using this from now on.
"Save copy in..." function copies files that have been cleared from session. | ragbor | Pro Tools TDM Systems (Mac) | 7 | 02-08-2010 12:25 PM |
Backing up/"Save Session Copy as" over a Network | biigbrew | Pro Tools TDM Systems (Mac) | 2 | 11-18-2008 01:48 PM |
"Save Copy In..." Never Works Properly! | reichman | Post - Surround - Video | 21 | 11-12-2008 09:54 AM |
"save session copy in" audio file name shortening | simonchase | Pro Tools TDM Systems (Mac) | 2 | 05-10-2002 04:39 AM |
"Save Session Copy" MUST copy AIIFF files??? | BHeller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-11-2001 12:33 AM |
