\"Play Pause\" mode?
Anyone have any ideas on disabling the "play pause" mode? In the transport, the stop button is lit, and the play button flashes when I hit play. The counter doesn't actually start counting until about 4 seconds into playing. I have no idea how I enabled this function, but would like to get out of it.
Thanks! |
Re: \"Play Pause\" mode?
Turn off pre-roll
Sounds to me like a click/count off issue. Is the blue box next to the metronome flashing too?
How many bars does it indicate? You can change this by double clicking on it and opening up the click/count off options window.
Pro Tools 2019.6 iMac (Retina 5K, 27-inch, Late 2015) OS 10.14.6 4 GHz Intel Core i7 32 GB 1867 MHz DDR3 Apogee Symphony MKII Thunderbolt 2X6 |
Pre-roll is off, but even if it wasn't, the cursor would move in the timeline, and the counter would still roll with the initiation of "play." I read something on the Digi site about this... this mode pre-loads the buffer when playing files with a large number of tracks, but I only have 7 tracks in this particular file. And their suggestion for disabling the mode does not work.
thanks |
Does this happen after leaving a session unattended for a while? Does the session play, or just light up the controls then stop?
Recording artist/Engineer/Producer Waves beta tester |
It does sound like you just have countoff enabled. In the transport, the button between Midi merge and metronome.
If thats not it...try decreasing the hardware or playback buffer
Intel iMac OSX 10.4.10 2.33Ghz Intel Core 2 Duo 2GB RAM Pro Tools 7.3.1 MBox 2 Pro |
Pause Mode in PT 10 | dr_daw | macOS | 7 | 12-22-2012 09:07 AM |
Pause Record Mode Fix? | CriminalRock | macOS | 2 | 08-19-2012 10:09 PM |
Pause record mode | MatthieuH | Pro Tools M-Powered (Mac) | 0 | 05-01-2008 08:51 AM |
Wierd "pause" mode | Tim R. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-06-2007 02:05 PM |
rehearse in rec pause mode | T Kowalsky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-21-2002 03:02 PM |
