Mixing RAM brands - same specs
Have any of you had any bad/good luck mixing RAM brands?
I have 1GB of PC3200 G.Skill RAM right now, and I might be adding 1GB of pqi brand. both have the same latency, timing, etc. Latency: 3 Timing: 3-4-4-8 at 1T. I've mixed brands and even types in the past with no bad results, just not sure with the PC3200 and up RAM if it's choosier. Kip
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
Re: Mixing RAM brands - same specs
I personally would be very careful with that.
My PC was running first with one 512 MB Infineon DDR 400 Modul. I had another Infineon 512 MB installed 6 weeks later. They didn't match although same brand, same type, but... different production batch #! The shop had to put in the same to get my PC working properly. I put in two 1GB Infineon this year, but bought two at the same time and made sure I could return them in case of problems. They run fine!!! I recommend get the same brand, but even then first give it a try and make sure you can return it! My 2C
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Need gear advice bad? Pro Tools 10 & mixing brands of converters | Christian | Pro Tools HDX & HD Native Systems (Mac) | 1 | 03-21-2013 02:53 PM |
Need gear advice bad? Pro Tools 10 & mixing brands of converters | Christian | Pro Tools HDX & HD Native Systems (Mac) | 6 | 03-18-2013 09:56 PM |
Mixing converter brands | midnightsun | Pro Tools TDM Systems (Mac) | 1 | 05-12-2008 11:31 AM |
CDR brands | proximityeffect | Pro Tools TDM Systems (Mac) | 6 | 02-23-2001 10:42 AM |
DDS 4 which brands | Kurtstudio | Pro Tools TDM Systems (Mac) | 0 | 04-27-2000 08:12 PM |
