Headphones as microphone?
I have plugged my headphones and my powered Moonsoon speakers into a Y connector that I plugged into the headphone output of my Edirol UA-3. The headphones now act as a sort of microphone (If I tap on them I hear the sound through my speakers). This works even if I disconnect the Y connector from the UA-3.
Can anybody explain what's going on? John |
Re: Headphones as microphone?
The speakers are acting as a microphone diaphragm and converting the sound into an electrical signal. You should try using a woofer as a large diaphragm mic to capture ultra lows....a well known trick by now for kick drum and bass cabs.
Michael |
Thanks for the explanation, Michael.
When things like this surpise me I realize that my ideas about electricity aren't quite correct. I think of the headphone output as the source of a signal and the headphones and the powered speakers as an outlet for that signal. I think of the Y connector as _splitting the signal (it's called a "splitter", right?), but my recent observation shows that the Y connector is a _connector, in this case connecting the speakers, headphone, and UA-3. John |
Another useful trick with headphones is to use them as a contact mic for acoustic instruments without electronics like guitars or upright basses. Just put the ear-pieces over the instrument body, plug it into the input jack of a tuner and voila! You can quickly and accurately tune to the rest of your track.
Tony
___________________________________________ Mac Pro 2010 2 x 2.66 / 40GB RAM / OSX 10.13.6 / PT2020.5 / Metric Halo ULN-8 |
sometimes i use the headphones as a mic for tuning stand up bass or acoustic guitar
just straddle it on the body and plug it in a tuner VERYVERY accurate
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I was doing a live show years ago and the alignment pin fell out of the mass connector on my snake which allowed the snake connector to be hooked up backwards. I was running a CD to test the system and its sound was coming out of one of the mics on stage, not the speakers. It was freaky for a while until we realized that the mass connector needed to be flipped around.
A speaker and a dynamic mic are basically contructed the same way, just different sizes.
www.barnabas.com Barnabas MultiMedia |
Microphone Help! | Mvrphy | General Discussion | 7 | 02-26-2012 12:20 AM |
Microphone and Headphones sound WEAK..* PLEASE SEE PIC * | yummyph0916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-20-2011 08:46 AM |
mic pre VS microphone Help | happasito | Pro Tools TDM Systems (Mac) | 1 | 03-01-2005 07:26 AM |
mic pre VS microphone Help | happasito | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-01-2005 02:23 AM |
Lag when using microphone. | Michael McCarthy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-09-2003 03:30 PM |
