Keeping mixer settings
Can anyone suggest the best way to do this. I've recorded 4 songs which are quite similar sounding. I've mixed one, applying various plug ins and grouping etc. How can I call up exactly the same settings when I go to mix the other three songs. i f I create a mix template it also recalls the tracks from the first song. do i clear selected regions and then import the files from the other tracks or is it all much simpler? Thanks. |
Re: Keeping mixer settings
Just remove all audio from your mix template. (Make sure to remove it from the session and not delete it from the disk.) Then save the template. It should open with empty tracks.
Dual 2.3 GHz PowerPC G5 2.5GB RAM OS 10.4.6 HD 2 Accel PT 7.1cs9 192 I/O |
Thanks for the replies.
It seems like there is no EASY way to do this which is crazy since it's such an obvious requirement |
keeping mixer view open | aldersyde | Pro Tools 10 | 9 | 09-11-2023 03:36 PM |
keeping song settings on other sessions... | Tomby | Tips & Tricks | 3 | 05-10-2008 01:54 AM |
PT6 problem with keeping settings. | bzldzl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-27-2003 03:40 PM |
Keeping tracks in phase due to mixer ch. inserts | bryanbassett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-27-2002 03:05 PM |
Mixer Settings | Eric Amdahl | Pro Tools TDM Systems (Mac) | 0 | 06-26-2001 06:20 PM |
