Old 01-14-2007, 06:28 AM
Palli-Moon Palli-Moon is offline
Default About having a dedicated HDD for audio
Hi, want to ask a few questions about dedicated harddiskdrives for my pro tools audio files.
I recently bought a "LaCie d2 Hard Drive Extreme with Triple Interface" wich I was planning on using as an audio harddrive.
Firstly, isn't this a pretty good HDD to use as a dedicated audio HDD? I read the support on digidesign.com and it said that drives with Oxford 912 bridge are qualified with FireWire 800 for Pro Tools 7.3 on MacosX and as far as I know this drive has it.
Secondly and more importantly, if I want the best performance possible should I only put the audio files on the disk? I know that as a dedicated harddrive your not supposed to put other things on it but should I also save my pro tools session somewhere else?
Here's my setup:
I'm running Pro Tools 7.3.1 on MacBook Pro Core 2 Duo and I'm using the classic Mbox
I think that's all I need to know for now
Old 01-14-2007, 08:02 AM
req06 req06 is offline
Default Re: About having a dedicated HDD for audio
This disk should be fine, I have Lacie D2 FW800 drive and its worked perfectly day in day out for the last couple of years. Just save your whole session to the Lacie, no need to save your .ptf/.pts files to somewhere else. Basically keep the lacie for your work, rather than running apps from it or anything else.
You should have no problems.
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4
Old 01-15-2007, 01:29 AM
That answered all of my questions, thank you
more than two dedicated audio drives??? xodiac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-09-2008 07:47 PM
dedicated audio drive? fubanger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-01-2007 09:33 PM
New dedicated audio drive (BANGAH) 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-14-2003 01:01 AM
Dedicated audio drive and jumpers Jay_Mora 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-30-2001 04:35 AM
Dedicated audio 20 GB ATA Drive with 001? tombi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 04-26-2000 04:06 PM
