Old 06-04-2006, 08:43 PM
Palli-Moon Palli-Moon is offline
Default Novation midi-keyboards
I was wondering how will the Novation Remote (SL to be specific) keyboard work with pro tools. I assume the keyboard itself is not going to have problems but I was wondering about the other controls.
P.S. I realize that on the site they don't mention pro tools as supported
Old 06-07-2006, 03:34 PM
Default Re: Novation midi-keyboards
anyone?
Old 06-08-2006, 04:04 AM
Sonny in London Sonny in London is offline
Novation have recently released an update to the SL range that includes an emulation of the CS-10 control surface as a manual template. This lets you select it manually from the SL in order to have the faders map to the mixer faders, mutes and such. It's not fully set up, but it's a start. I'm planning on tweaking mine to make it more usable - I'll post the template up here when I do.
As yet there is no 'Automap' template that automatically maps all the controls to any plug in that you might use like in Reason, Cubase, Logic or Ableton. It may come in the future, but due to the different type of architecture in Pro Tools I imagine it might take a while. Also, Digi and Focusrite aren't exactly best buddies any more, what with the Saffire range stepping on the MBox's toes and all that.
Other than that, my 25SL is a wonderful bit of kit - loads of controllers, nice keyboard, XY pad, big LCD displays, loads of templates and it looks sexy.
If the Automap feature becomes a reality it will truly be the best MIDI controller out there - using this feature in Reason, Logic and Ableton Live is amazing for workflow and creative inspiration.
Peace
Sonny
Old 06-08-2006, 10:39 AM
Thanks for this answere mate it really helped.
Old 06-12-2006, 07:56 PM
Brooklynite Brooklynite is offline
Just bought a ReMOTE 61 SL and it's a fantastic controller. Question for you Sonny. I just installed the CS-10 emulation and it seems to be working. However, I can't figure out how to swith between groups of faders and also the track names don't show up on the Novation's screen. Is there a trick I'm missing?
Thanks,
Eric
Old 06-12-2006, 08:39 PM
Equality 7-2521 Equality 7-2521 is offline
Thanks,
Eric
Use the left and right cursors to switch between banks of 8 tracks. As Sonny said, the template provided is not really set up completely. It needs tweaking. Im not sure if the cursor buttons were included. You will not see the track names because the template is not an automap and therefore will not recieve visual feedback from the PT interface. That will only happen when there is Automap. Until then you have to put up with Fader 1, Fader 2 etc (or whatever you set them as). Last I heard from Novation, they have the go ahead from Digi to develop a HUI emulation which is expected to give the same results as Automap. They are looking into it but it will leikely be down the track that it becomes a reality.
PT LE 7 & MBox
Windows XP SP2
P4 3.0GHz CPU, Intel 865/PE/P Chipset
1GB RAM
2 X Seagate Barracuda 80GB HDD
Novation Remote SL MIDI Controller
Can I use two midi keyboards on my 003? goga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-09-2010 08:06 AM
Midi Keyboards afox MIDI 4 03-11-2007 10:56 AM
Midi Keyboards afox MIDI 0 03-09-2007 05:30 AM
MIDI Keyboards Eman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-11-2005 05:53 PM
MIDI Recording in Win98 Protools LE and keyboards...Can I use non-General MIDI sounds Shan Plourde General Discussion 2 01-18-2001 08:34 PM
