Help...plug-ins not processing with audiosuite
I havn't been able to get any plug-ins to process through audiosuite. They work if I use them on inserts. But I only want to process 3 regions on 3 different tracks. Any Ideas?
Re: Help...plug-ins not processing with audiosuite
What happens when click the process button? Here are the 2 most common operator errors with audiosuite plug-ins: 1. The 'Use In Playlist' button is not selected and the processed file is landing in the region's list only. That will make it appear that nothing happened on the track where you had selected. 2. The processing source is set to 'regions list' and unless you select something from the regions list directly or select an area on the track that includes an entire regin, you'll get the "no audio was selected" error. Good luck. |
AudioSuite plug-ins Processing Problem | quiquedom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-01-2011 02:51 PM |
Issues processing with audiosuite plug-ins | basicrecordings1985 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-14-2008 11:15 AM |
AudioSuite Processing Doesn't | viking3 | Pro Tools TDM Systems (Win) | 3 | 11-17-2007 06:50 PM |
Help me! Volume dip when processing Audiosuite plug-in's | tftv86 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-28-2007 09:10 PM |
Audiosuite Not Processing | Lonnie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-27-2004 09:16 PM |
