Old 11-17-2020, 02:40 PM
Magnetic Magnetic is offline
Default Re: Which IP ports for AVID Control?
Similar issue. Every time I launch ProTools I have to go thru this dance:
1. Turn on WiFi on the Mac
2. Wait until the Dock and Control Ap show up in My Surfaces
3. Remove both, and wait until they show up *available* in All Surfaces
4. Turn off WiFi on the Mac
5. Add both to MySurfaces
After than, everything works. I'm not running a VLAN.
Old 11-17-2020, 02:58 PM
EddieJones's Avatar
A few questions.
  1. Do you really mean every time you launch Pro Tools...or is this when you start the Mac ?
  2. How is the iPad connecting to your network...directly to the Mac or to a Router (or even the camera kit cable?)
  3. How is the Dock connecting to the network?
  4. Is EuControl set to auto launch?
Old 03-05-2021, 10:46 AM
1. Yes
2. WiFi (same router/same subnet as iMac)
3. Ethernet cable to switch->router in #2 above
4. Yes
Old 03-05-2021, 11:13 AM
EddieJones's Avatar
Can you try as a test turning of EuControl Auto Launch? and doing it manually.
Old 03-09-2021, 02:16 PM
No difference
Old 03-09-2021, 02:54 PM
EddieJones's Avatar
have you tried connecting the imac via ethernet to the router (and not use WiFi)
Old 03-11-2021, 10:58 AM
The iMac _is_ connected to the router via ethernet. The only time I turn on Wi-Fi is to get eControl to connect. Once that's successful, I turn Wi-Fi back off.
Old 03-11-2021, 12:01 PM
EddieJones's Avatar
Turning Wifi on or off whilst EuControl is running i known to cause issues, could it be that ?
Old 03-12-2021, 12:26 PM
Well, turning on Wi-Fi temporarily is the only way I can get EuControl to see AVID Control, hence the problem. Is there some preference to reset EuControl's network stack?
Old 03-12-2021, 12:37 PM
EddieJones's Avatar
Maybe run the installer and select remove all apps and remove all prefs. Reboot and then install EuControl with Wifi Off.
Most Waves plugins cannot be set properly from Avid control surfaces / Avid Control? XJENSEN Avid S1, S3, Dock and Control App 3 08-11-2022 06:59 AM
Avid Artist Mix - only ports 1-4 work, I've tried everything! joren Artist Series 5 05-28-2014 03:10 PM
Artist MC Control & Mix Midi ports broken NickNack Artist Series 7 01-07-2014 04:32 AM
Machine Control COM Ports: Sync I/O vs CPU Tom Smith Post - Surround - Video 5 08-19-2008 02:10 PM
9 pin Machine Control ports on USD or SYNC Fritz Post - Surround - Video 16 04-16-2004 07:30 PM
