Old 06-24-2015, 11:40 PM
rcd rcd is offline
Default Duplicated track not cancelling when inverting phase...
We've noticed some phase issues so performed a duplicate track phase inversion and the 2 identical tracks are not phase cancelling (when one of the phases is reversed). What are the possible culprits of this issue and what needs to be done to fix it please?
Thanks in advance for any info.
PT12HD Native
Windows 7
Avid HD i/o 16
Old 06-24-2015, 11:59 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Duplicated track not cancelling when inverting phase...
PT12HD Native
Windows 7
Avid HD i/o 16
any plugins on the tracks or just pure identical audio? Plugins that modulate will effect cancelation but not stop it totally.
Is it cancelling at all or is nothing happening. Identical audio with the same phase will just get louder.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-25-2015, 02:35 AM
midnightrambler midnightrambler is offline
Timing (e.g. audio in wrong place / different latency on plugs)
Different volume levels
Different EQ
Different FX (esp modulating ones such as chorus etc as mentioned above)
Different Compressor
Er....anything else?
Old 06-25-2015, 04:26 AM
SOUNDDECISION SOUNDDECISION is offline
What plugin is being used to invert the phase?
Do you have the same plug in on both tracks? (one not inverted)
Do you have ADC turned on?
Old 06-25-2015, 05:05 AM
I've compared mixes printed offline vs online and found that there can be very small discrepancies with some VIs, e.g. Battery, where the sounds won't entirely cancel as they are a few samples out.
Old 06-25-2015, 09:37 AM
john1192 john1192 is offline
i find if there is a modulation on a plugin it could happen Because, the modulations are not uniform .. like a phaser on guitar does not do the same thing twice ..
maybe ??
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-25-2015, 12:04 PM
rcd rcd is offline
Thanks for all the replies! I tried the cancellation test using the Avid/Digi Eq Plugin and again tried is by inverting the identical track via 'options' and 'render' (I think, was an all-nighter last night)...
I'll try placing the same plug on the other track since I only had the one plugin inserted, there were no other plugs on either track.
I'll report back after I fire up today!
Thanks!
Rich
Old 06-26-2015, 04:48 AM
Postman Postman is offline
Avid/Digi Eq Plugin
Yes, it is true. Latency through some types of EQ3 are not the same when phase is flipped. Probably a bug. I've noticed it from time to time since PT10.
How do I UNlink a duplicated midi track from it's source? brandobean MIDI 3 07-26-2016 11:02 PM
Printing a track w FX = resulting track phase inverted? Ticker macOS 12 05-23-2014 11:45 AM
Inverting the phase of a track after the fact... KennyDeVries Pro Tools TDM Systems (Mac) 10 01-19-2008 10:40 AM
Inverting Jsswtpmp182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-01-2006 03:05 AM
Duplicated a Selected Track Riad Tips & Tricks 3 02-13-2005 03:41 PM
