Midi help needed with digi002 no midi at all
Hello, i own a digidesign digi 002, with pro-tools LE
and a Akai MPK49 with usb connection, in Reason i can use my digi as a soundcard, and the mpk49 works perfectly, but in Pro tools, i can use all the cool Digi002 features, but i cant get midi to work, i've tried to connect my mpk49 directly in my digi with midicables, but with no result, and the lights of midi in en midi out on my dont even light up..... does my digi needs repair?? or do i need a seperate power supply for my akai mpk49, since i use the usb for power..... I tried all the settings, downloaded the cs10 update, read every topic on the net about it.... i cant figure it out, used every setting in pro tools possible.... can someone please help me??? |
Re: Midi help needed with digi002 no midi at all
Go to the Program Files>Digidesign>Pro Tools>Drivers and double-click on the MMERefresh app. Do the MIDI ports now show up in Pro Tools?
i can see the ports in pro tools, thats not the problem, but when i select them in pro tools nothing happens, and the lights of midi in and midi out on my digi stay off,and i suppose they should light up when i plugged in midi, i read that i should light up everytime i do something on my keyboard, but that doesn't happen either...
but i will try the mmerefresh app.... |
didnt work....
please someone knows what i do wrong? or is my digi f$@#ked? |
to test, i've powered the mpk through another laptop, while having the midi in and out directly in my digi still no signal, no midi lights....
some help please????
i need to know if i need to have my digi002 repaired or not....
Helloooooooooooooooooooooooooooooooo?
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
did all that, i gave up on the midicables, and back the usb port, i can select it in pro tools, but i cant seem to make it work...what do i overlook?
HELP needed with MIDI | LiteraryLady | Windows | 2 | 12-18-2012 09:36 PM |
Help Needed - Midi | JackSummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-04-2007 04:36 AM |
USB Midi help needed ... | Jonah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-19-2003 12:03 AM |
Digi002 Midi uses the new Midi TimeStamping??? | Targon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-08-2002 10:11 AM |
MIDI HELP NEEDED | laupflow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-17-2002 10:50 AM |
