Old 11-19-2015, 12:02 PM
hugocentrique hugocentrique is offline
Default MIDI brings up "Updating track transcription" dialog
I have a MIDI track in a session. Every time I touch it (move a region, enable Real-time properties, etc), a progress box appears, saying "Updating track transcription". And it takes FOREVER. It is really slowing down my workflow (and bringing up my frustration).
Is this expected behaviour? It's driving me nuts!
OSX 10.10.5
PT 12.3.0
Old 11-19-2015, 01:23 PM
Stig Eliassen's Avatar
Default Re: MIDI brings up "Updating track transcription" dialog
I have never heard of that. What happens of you consolidate the clip into a new one (select the clip and press Shift+Option+3)? Do you get the same dialog box?
Old 11-19-2015, 03:43 PM
studioj11 studioj11 is offline
Do you have a score editor open? That is the only time I have seen this dialog...
Old 11-19-2015, 07:05 PM
Dang that was it! I thought I had closed the window...
I must admit that I am a bit perplexed at the time it takes though!
Thanks a bunch!
Old 11-19-2015, 10:02 PM
Cool, no problem. This is a bug that I hope gets addressed eventually... try working with a score with any amount of length or large number of tracks and the score editor essentially won't open because of this lengthy process bar.
PT11.n - no option to change sampling rate in "save as" dialog BCnSTL Pro Tools 11 3 03-18-2014 04:23 PM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
"Rebuilding Mixers" "Updating I/O"? bluesfrequency Post - Surround - Video 4 04-04-2011 05:00 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
Faster Dialog Editing "setup tips, mouse,etc. needed" Erinugene Pro Tools TDM Systems (Mac) 17 01-25-2003 12:06 AM
