Old 04-26-2012, 08:45 PM
prestA17 prestA17 is offline
Unhappy Venue 3.0 SNAPSHOT/SAFE PROBLEM
I am having big problems using snapshots, in particular the AUX MON parameter. I am the FOH engineer for Denton Bible Church and we just had our brand new Venue installed 2 weeks ago. The problem seems to be the Snapshots working with the Recall Safes.
Everything for snapshots worked fine when I started to build our Sunday morning show last week. I only automated the Fader and Mute parameters. They all recalled properly and worked great. When I went in to Recall Safe particular channels it would adhere to the Safes.
This week I am adding in AUX MON to the snapshots and have been trying to figure out why it will only work when the Recall Safe "Master ON/OFF" is in the OFF position. This means I can't utilize any of the Safes because when the Master is in the OFF position it globally disables them. When I turn it on and I make sure to de-select all AUX MON, but when I go in to recall my snapshot it won't recall them(it is like they are still checked in Recall Safe).
So my only solution right now is to globally disable all of my recall safes, which makes things a lot harder than they need to be. I HAVE been able to get this problem to duplicate in the offline software. To troubleshoot it I have tried building new shows, snapshots, make sure they are AUX MON and not AUX FX, etc... Does anyone have an idea as to what the problem might be or are experiencing the same problem? Thanks for any help!!
PrestA17
Digidesign Venue 3.0
MacPro running Leopard
ProTools 10 HDX
Old 05-01-2012, 09:11 AM
Mike Z's Avatar
Mike Z Mike Z is offline
Default Re: Venue 3.0 SNAPSHOT/SAFE PROBLEM
prestA17,
Can you make sure "CH SENDS" is not checked in Snapshots>Recall Safe>Outputs>Aux? It sounds like this might be the problem.
Thanks,
-Mike
Avid Live Sound Support
Venue FWx Problem mightyeskimo VENUE Live Sound Systems 14 12-23-2013 11:05 AM
Artist mix/control snapshot automation venue style BBBarcus Artist Series 0 11-14-2013 07:15 AM
Auto safe for individual auxes on VENUE? melodydetective VENUE Live Sound Systems 3 07-15-2013 11:04 AM
Problem wiht VENUE SyncMaster VENUE Live Sound Systems 2 02-20-2009 05:05 PM
"Solo Safe" problem teacherman Pro Tools TDM Systems (Mac) 2 09-08-2006 06:48 PM
