Old 08-19-2010, 04:49 PM
bkurt bkurt is offline
Default 003 PT 8.0.4 Windows 7 not recording
I have seen some relevant posts out there with people having the same problem I am. However, I have yet to find an answer.
Windows 7 64 bit
Core i7
Pro Tools LE 8.0.4
003 Rack
Last night I tried to add a vocal part to a previously recorded guitar track. The guitar track was recorded a couple of weeks ago on my current system. I plugged in my Shure KSM mic to input 1 on my 003 Rack. Made sure phantom power was on and the gain was up on the rack. Created a new mono audio track in PT. Set the input on the mono audio track to input 1. Record enabled the track. Talked into the mic. No signal showing up on the track in pro tools. I increased the gain on the 003 to where the clip indicator light was flashing on the 003. Still no signal in PT.
I have trashed my prefs. Restarted. Double checked the phantom power. changed mics. changed mic cables. Double checked the I/O settings. Any solutions?
(and yes.....I made sure the input on the 003 rack was set to mic not di)
Old 08-20-2010, 10:49 AM
rqstudio rqstudio is offline
Default Re: 003 PT 8.0.4 Windows 7 not recording
That was kinda my question, does the DI work? Does input 2 work? Sounds hardware related.
www.rickqueststudio.com
Old 08-20-2010, 03:57 PM
The Mic inputs 2-4 don't work either. The DI (or line) inputs 1-8 don't work either. On the rack I can tell I am getting signal because the peak indicator light comes on but still no signal in pro tools
Old 08-20-2010, 05:10 PM
Not sure what to tell you. I spent all day recording on my 003/8.0.4/Win7 64 bit and never had a recording issue.
Old 08-20-2010, 05:13 PM
I have been using this system for a couple of months and am just now having this issue. I also experience random clicks and pops every now and then. I usually have to restart my computer and they go away.
Old 09-01-2010, 08:45 AM
davidevans512 davidevans512 is offline
I am having the same exact issue you are having but am running Pro Tools LE 8.0.4 on a Dell e1505 laptop with Windows XP. I have a feeling the issue we are having is related to the upgrade to 8.0.4 and something to do with the i/o because I had used my mic and DI inputs to record guitar parts a couple weeks ago but ever since I upgraded to 8.0.4 I cannot get any signal into pro tools from either a microphone or DI or the analog inputs (tried inserting an outboard compressor to compress a bass track and the signal was being sent to the compressor and showing up there but not coming back into pro tools). Please let me know if you figure this issue out or else if I can't fix it I will either try system restore back to before I upgraded Pro Tools or contact Avid customer service.
Old 09-01-2010, 07:01 PM
My opinion only, but if I were running XP, I would not go to 8.0.4. 8.0.1cs2 worked better for me(I still have that system drive available in case I run into a snag with my Win7/64 bit setup).
Old 09-01-2010, 10:34 PM
Benoni's Avatar
Benoni Benoni is offline
+1
Always have that backup handy.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 09-02-2010, 12:46 AM
TOM@METRO's Avatar
As you can see in my signature, 8.0.1 cs2 is my choice for an XP system.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 09-02-2010, 01:39 AM
Benoni's Avatar
if on XP, be aware that Avid has announced it will not support XP or Vista after Pro Tools 8.0.4
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Pro Tools not recording after windows update!?!? hac23_99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-14-2010 06:24 PM
Recording on a Laptop question (windows XP) Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-25-2008 06:18 PM
Recording of sound in Windows XP... GW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-13-2005 03:49 AM
How to set up a Windows XP computer for recording. GothicV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-01-2004 01:53 PM
Use these Windows set-up tips for recording audiotracker Digidesign Hardware & Software 0 05-09-2001 05:57 PM
