playback delay when quicktine is online
Hi all,
I found a similar problem with the Mac guys, but working on PC I have also troubles with quicktime playback. When a QT is on a video track, it takes about 3 seconds after I pressed play before the system starts. With the video track offline, it is no problem. I am on Pro Tools 7.3.1cs7 on PC, Pro Tools LE, DV Toolkit 2. Anyone with similar problems? |
Re: playback delay when quicktine is online
When usin a videocodec like dv or jpg there are no delays.
If you use H264 or other modern codecs on slow cpu machines, a delay will occur. But 3 seconds is much. What CPU do you have, Ram, Quicktime version If scrolling gets also slowly, you definitly have a codec problem! ....... Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
My system info
Mainboard : Asus P5K-E Chipset : Intel P31/P35 Processor : Intel Core 2 Duo E6750 @ 2666 MHz Physical Memory : 2048 MB (2 x 1024 DDR2-SDRAM ) Video Card : Nvidia Corp GeForce 8600 GT Hard Disk : WDC (200 GB) Hard Disk : WDC (80 GB) CD-Rom Drive : LITE-ON DVDRW SOHW-1213S SCSI CdRom Device Monitor Type : LG Electronics L1919S - 17 inches Monitor Type : Samsung SyncMaster - 19 inches Network Card : Marvell Semiconductor (Was: Galileo Technology Ltd) Yukon 88E8056 PCI-E Gigabit Ethernet Controller Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 3 DirectX : Version 9.0c (November 2006) Using Quicktime 7, updating as we speak. A bit strange the PC wizard says I have only 2 G Ram, While I have 4 inside and my task manager also says 4 Quicktime files are supplied by video editor, don't really know what codec he used... |
select another soundcard (in- and output) in the windows preferences than the digicore audiomanager.
at least this causes the problem in macOSX |
open the file in QT then open the Inspector (control+i I believe on PC) this should tell you the codec used, length, bit-rate
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
if your ram is reading incorrectly then try and re-seat them in another order. this happens sometimes.
also, if they're on some sort of board, make sure you have them in-line without gaps (ram placeholders) in between.
NuanceTone.com |
Btw, update QT, 7.6 if I'm correct, fixed the problem!
Go to system prefs / sound and put your output in internal speakers! restart Protools.
I Find this happens when some part of the current session regarding video in the session gets corrupted. Save time:
Save Copy in. Reboot PT/or computer. It goes away. Especially check with H264, which needs to be set to "key every frame" PT 9.05 and those before!
Dick Maitland C.A.S. |
HD Native online record delay | Hugh-H | Pro Tools HDX & HD Native Systems (Mac) | 10 | 07-30-2011 04:35 PM |
Loop Playback / Online incompatible in PT8 | dave@ir | Pro Tools TDM Systems (Mac) | 3 | 04-22-2010 04:31 AM |
Playback Latency with online video PT. 8.0 | protoolsnerd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-27-2009 03:17 PM |
7.4.2pr has a delay before playing when video is online | Sonic Nomad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-12-2008 01:32 AM |
AV Option Online Record Delay? | Matt Foglia | Post - Surround - Video | 0 | 07-13-2001 12:05 AM |
