Old 06-10-2015, 10:06 AM
shmulik shmulik is offline
Default Bounced WAVs don't play on iPod
Hi all,
I'm having a small but frustrating problem. I'm bouncing down some rough mixes to WAV and I want a portable way to listen to them, so I've tried to put them on my ipod. I made a 10-song "album" of these mixes and I find that the ipod skips through most of the tracks as if they're unreadable.
In itunes on my computer, I can play any of the files that are troublesome on the ipod. I also deleted the files from the ipod and re-imported them once but found the exact same problem.
Have any of you encountered any problems with WAVs created by Pro Tools not reading on ipods?
File storage space on the ipod is not an issue, for what it's worth.
Old 06-10-2015, 10:17 AM
john1192 john1192 is offline
Default Re: Bounced WAVs don't play on iPod
is it a format thing ?? 24/96 does not play on my iphone or old ipod .. are your Wav's high resolution like 24/48 or 24/96 ??
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-10-2015, 10:22 AM
mesaone mesaone is offline
More info needed. iPod specs say it supports WAV, more info here: https://support.apple.com/kb/ta38530?locale=en_US
But some of those links are dead, so I can't seem to find max supported bit depth and sample rate.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
DonaldM's Avatar
DonaldM DonaldM is offline
Originally Posted by shmulik View Post
Hi all,
I do this quite often on my iPhone. If you just want to listen to your mixes, then I suggest you bounce as MP3. Then, you have to ADD the MP3 to your iTUnes library. What I've done is create an iTunes Playlist called "My Mixes" and then I add any bounced songs to that once I've added them to the iTunes library. Then, when I sync my iPhone to my laptop, I just have to make sure I have that Playlist checked for syncing, and any new songs I've added will now be on my iPhone.
If you want to use the WAV files, then you must bounce as 16bit, 44.1k sample rate, otherwise, it won't work. But, MP3s should be fine for just listening back on various systems.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
cant play bounced wavs - codec? Charlesh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-03-2009 06:49 PM
Signal levels of bounced WAVs David Topple 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-17-2009 11:08 AM
Plays imported wavs, records new wavs, BUT WON'T PLAY NEWLY RECORDED WAVs cmoseman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-02-2008 10:20 AM
Bounced song won't play in Ipod... PT or Ipod prob nica 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-03-2006 03:08 PM
Playback of bounced wavs on XP neelhaq79 Pro Tools TDM Systems (Win) 1 10-09-2003 10:47 AM
