Old 09-22-2021, 01:58 PM
filipeguerra filipeguerra is offline
Default Protools Crash on Hide and Make Inactive Channel
Every time I set a channel to Hide and Make inactive, the Protools crashes and takes about 1 minute to get back to work. My system: Macbook Pro 2020 - i5 16gb Ram Mac BigSur Prootools 2021. Can anyone help?
Old 09-22-2021, 02:02 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Protools Crash on Hide and Make Inactive Channel
Hi, What plugins are on the channel when you try to Hide and Make Inactive? Does it happen if there are no plugins on the channel?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-22-2021, 02:03 PM
JFreak's Avatar
JFreak JFreak is offline
Sounds random. Maybe you should backup everything, erase the system drive and reinstall everything. It is surely not a PT problem but something on your system.
Janne
Old 09-22-2021, 07:48 PM
s.d. finley s.d. finley is offline
I have practically the same MBP as you also on 11.6 Big Sur with PT 2021.7 and I am not experiencing that crash. I use hide make inactive function all the time. Must be a plug in. What do you have on the tracks? Have you tried hide and make inactive on a track with no plug ins?
sdf
www.sugarhillstudios713.com
Old 09-23-2021, 07:49 AM
I discovered the error: when I am using Bluecat Audio Patchwork.
Old 09-23-2021, 07:52 AM
JFreak's Avatar
VST's have always been a problem
Janne
Old 09-24-2021, 05:45 AM
cwsand's Avatar
Is it the Bluecat plugin itself or the plugin it's hosting? I use Bluecat Patchwork all the time with no issues. See if the problem occurs when Bluecat isn't hosting any plugins. If not, then it may be one or a few vst plugins causing the problem.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
2021.6_No Hide and Make Inactive Menus from right-clicking on Track Nameplate or List js_nyc Pro Tools 3 07-21-2021 01:38 PM
Hide and make inactive issue with folder (still visible on S3) Manaberry Avid S1, S3, Dock and Control App 3 08-27-2020 07:55 AM
suddenly can't make tracks inactive..it thinks they are inactive but they are active? awritersparadise Pro Tools 2019 0 08-27-2019 12:23 PM
Mc Control, Hide inactive not responding soundworthy Artist Series 0 01-22-2016 10:37 PM
Hide inactive tracks... Derekten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-30-2008 02:10 PM
