Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 02-17-2010, 08:29 PM
fenderwrx fenderwrx is offline
Default Pro Tools LE with MBox and M-Audio ProjectMix I/O
Hello Everyone,
I'm new to this forum and the Pro Tools world.
I've purchased Pro Tools M-Powered 8 and an M-Audio ProjectMix I/O.
I'm curious what I should do if I purchase an MBox Pro Factory to travel with (I like to do live recordings of practices and gigs but don't want to haul the PJM everywhere)
I know the MBox pro factory comes with Pro Tools LE and a lot of extra stuff...I'm wondering if:
A) If I can use my PJM I/O with Pro Tools LE..or if I'd need two different copies installed because one system is an M-Audio...
B) If I have to keep M-Powered Pro Tools if an MBox would interface.
I'm assuming PJM will work with LE but correct me if I'm wrong.
I did a forum search and a google search and couldn't get the answer I'm looking for..
Thanks in advance for your input.
Old 02-18-2010, 01:04 AM
sortasalient sortasalient is offline
Default Re: Pro Tools LE with MBox and M-Audio ProjectMix I/O
If you buy and M-audio interface, it works with Pro Tools M Powered. If you buy a Digidesign interface, it works with Pro Tools LE. That's pretty much the deal.
Old 02-18-2010, 03:29 PM
obiwan177 obiwan177 is offline
But you can still use the ProjectMix as a control surface for LE, just not an audio interface. You could buy the MBox and then run LE on the road, and then open them up at home to mix with the ProjectMix. Or you could just get a smaller m-audio interface, and only deal with one program. That probably is also the cheaper route.
Old 09-08-2010, 05:28 AM
dred dred is offline
please tell me how or show me links where i can read about it. thanks
www.dredziarz.pl
Old 09-08-2010, 09:18 AM
Dism Dism is offline
It's pretty easy.
You set it up the same way you would if you were using M-Powered. Put it into Pro Tools mode, and assign it as a control surface under Peripherals.
You won't have any of the I/O available though.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 09-08-2010, 03:51 PM
Skyflash Skyflash is offline
As long as you have the same version number you can have both Mpowered and LE on the same system.
They will both share the same plugins.
2006 'Blackbook' Core Duo 2.0 ghz.
2 gig OWC RAM
10.5.8
PT Mpowered 8.04, Logic 9.1.1
Waves SSL,Omnisphere,Korg Legacy Digital
Absynth 4, EZ Drummer
Project Mix I/O w/ Black Lion Mod
Axiom 61,25, Korg Nano Pad
Old 09-19-2010, 04:12 PM
moskasound moskasound is offline
If I understand you correct, you just want to be able to use both LE and M-Powered versions, using the appropriate interface for each.
I have several songs that were produced on LE system with my Digi001...I can still open up those files with my M-Powered system, despite not having the 001 any longer.
I guess the real question would be...can both versions exist within the same system? I've never tried it but now I'm curious.
iMac 3.06 Core 2 Duo 27"/4 GB ram
Mac OSX 10.6.4
ProTools, M-Powered 8.0.4
M-Audio ProjectMix
LaCie Quadra Drives
SampleTank
Abelton Live
Old 09-19-2010, 11:33 PM
tomric tomric is offline
I would suggest a small M-Audio Interface instead of the MBox and use it with your M-Powered version, as long as you don't need features that aren't supported with it (for example DV-Toolkit).
[Macbook Pro 15" C2D, Pro Tools 9.0.5, M-Audio Profire 2626, Terratec EWS Mic8] - [Mac Pro Quad-Nehalem, Pro Tools M-Powered 9.0.5, M-Audio Firewire Solo, M-Audio Oxygen 49]
Pro Tools 11.0.1 and 11.0.2 with M-audio Projectmix i/o johannesj Windows 4 02-07-2014 07:23 AM
ProjectMix I/O - audio only in Pro Tools, nowhere else variex FireWire & USB Audio Interfaces (Win) 4 07-08-2013 06:23 AM
M-Audio Projectmix I/O + Pro Tools LE = ? Lord Hellsings 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-03-2009 06:57 AM
Cannot control GearBox Plugin via M-Audio ProjectMix I/O, via Pro Tools dartveiga Pro Tools M-Powered (Win) 3 11-11-2008 02:25 AM
Pro Tools LE & M-Audio Projectmix eviltobz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-19-2006 04:18 PM
