Old 07-16-2006, 07:30 AM
John H John H is offline
Default Mbox2 constant -6104, -6101 or Hardware not found!
I was working on a session last night with only about 10 tracks and maybe 5 or 6 plug-ins and it kept loosing audio and I had to re-open Protools LE once the cpu usage started reaching maximum.
Today, I got the hardware not found error on starting Protools LE over and over.
After swapping to every available USB port (not using a HUB by the way) I applied the 1.38 Firmware Update thinking it would help.
There was a lot of crackle, pops and noise coming from MBox2 audio while launching Protools LE, session opened fine then it gave me the -6101 error after playing briefly then running out of steam.
restarted mac
again, a lot of crackle, pops and noise coming from MBox2 audio, session opened fine then it gave me the -6104 error etc... like previous!
I tried creating a new session, added 1 audio tracks and pressed play only to get the -6104 error straight away!
I have an 800Mhz Quicksilver G4, 1Gb factory fitted RAM, 250Gb Maxline III system/storage drive in 2 partitions and 40Gb Western Digital drive dedicated to audio. Also, system is fully new install, dedicated to Protools LE 7.0, no quirky 3rd party control panels etc...
I avoided moving to Protools LE under OS X until I knew it was a workable system as previously used Toolbox XP system under OS 9 and wanted a similar plug and go experience under OS 10.4. I'm very disappointed in this. It worries the hell of me that it's a hardware error and it'll mean sending it back and messing around to get my £300 worth of kit working again.
It feels like the firmware update was rendered my system useless or at the very least added to the problem with the crackles etc... I can't stress enough how rock solid and well this system has worked with Protools LE up until now.
Please help!
Error Message 6104 and 6101 ckahle33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-24-2011 04:08 AM
PT8 constant -6101 cpu issue, Let's do something mistlabz Pro Tools M-Powered (Mac) 47 08-31-2009 05:15 AM
Consistant error 6104 and 6101 on Quad Core acronk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-20-2009 05:35 AM
Constant -6101 errors mpeddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 03-10-2009 09:03 AM
Constant H/W buffer errors -6101 -6104 -9128 alvarez1900 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 01-08-2009 11:58 PM
