Old 01-01-2022, 04:56 PM
jax_rox jax_rox is offline
Default Fosucrite d2/d3 update?
The Focusrite d2/d3 bundle has been a bit of a go-to for me for at least the past decade.
I've just upgraded to an M1 Max MacBook Pro. It's been quite the upgrade; my last Mac Pro was a 2015 trashcan model and I've been through two iMacs and a MacBook Pro since. This computer is the fastest I've ever worked on (probably in part because I was stuck on Pro Tools 2018 on macOS 10.12.6 prior to my upgrade).
I know Pro Tools isn't officially supported on Monterey yet, though it is supported on Apple Silicon via Rosetta. I've been running Pro Tools just fine and it zips; half my plug-ins (including Waves which are theoretically officially supported) don't work, but I've been able to get by as my most crucial ones do.
Except, of course, the Focusrite d2/d3 bundle, which won't even install. I've been looking for information on if/when they may eventually be updated to be able to support M1 via Rosetta, or if I should spend this time branching out to find something new to replace them. From what I can tell it's been a long, long time since the bundle has been even cursorily looked at, and other developers don't appear to plan to update many of their legacy products to M1 Silicon (iZotope, for example, don't appear to be invested in updating thei ExponentialAudio product line) so I'm guessing it's probably the end of the line (unfortunately).
Anyone have any further insight, or alternately a recommendation on what to replace them with?
Old 01-02-2022, 01:21 AM
Stephen Bond's Avatar
Default Re: Fosucrite d2/d3 update?
It's unlikely to be end of line support is my guess, but I could be wrong.
Have you tried v18.8? https://www.avid.com/plugins/focusrite-d2-d3#Downloads
If that won't install, how about copying the plugin into your plugins directory manually from a previous install?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 01-02-2022, 01:55 AM
I can confirm the d2/d3 both work on my M1 with 2021.12.0 and 11.6.1 so I am pretty sure they will make it to the latest OS at some point.
Stephen
Old 01-02-2022, 02:27 AM
I was able to install v18.8! I must have missed that and accidentally gone for v12.
Unfortunately, it does not work with Monterey; hopefully once Pro Tools gets official support, so too will this bundle.
Old 01-02-2022, 03:45 AM
Ben Jenssen's Avatar
Remember, they are really old, and personally I never found them to be anything special. Not twenty years ago, not now. I'd rather use EQ3 and Dyn3 that comes w/PT myself.
HTML code is On
Sierra 10.10.6 - To COMBO update - or App Store Update ? Seafoam_Green macOS 6 01-07-2024 05:19 AM
10.3 Update - Windows shutdown issue has returned. Update at your own risk. crm0510 Windows 14 09-19-2012 01:50 PM
10.5.6 update. Is it safe to apply the system update from 10.5.5? SBCCMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-02-2009 02:27 AM
Windows Update Vs Apples Software Update sunburst79 General Discussion 2 07-14-2007 06:40 AM
What is this Apple Update? Hard Disk Update...ver 1.0 McMasters Pro Tools TDM Systems (Mac) 1 06-30-2003 05:56 PM
