Excessive CPU Usage In Pro Tools with long sessions
Hello,
I have experienced a weird thing with long sessions (>10Minutes)! At the beginning of the song the CPU usage is 20-30%... and after a while it is increasing and increasing ... After 13 Minutes its 100% and the systems stops with the error 9128. I can´t record a full live mix to stereo without stoping - have to record step by step... Also sometimes some tracks get out of sync to the others... weird too! I have to restart PT to solve this problem. Any help? Here is my setup: Dual 2.8 QUAD CORE INTEL 6GB RAM OS 10.5.8 PRO TOOLS HD 8.0.3Cs1 MAGMA Expansion Chassis PE6R4 HD CORE HD ACCEL HD ACCEL UAD2 SOLO (not running with this session) SSL DUENDE PCI (not runing with this session) PCM96 Firewire Plugs in this session: EQ3, WAVES SSL, WAVES API, WAVES PLATINUM 7, TC MD3, SONNOX LIMITER, PCM96 (2), ALTIVERB6... THANK YOU |
Re: Excessive CPU Usage In Pro Tools with long sessions
I have mixed entire live concerts where I even had 3x2 hours in one session.
Around 60+ tracks and lots of plugs, all from one harddisk....I could even bounce the entire concert in one go. I'm pretty certain there will be some plug-in or the UAD to blame.
www.olipoulsen.com iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7 Apollo 8 / PT Ultimate 2020.9.1 |
What are your playback settings? specifically your hardware buffer size? this effects RTAS performance greatly if you have it too small. Those Altiverbs are likely candidates!! also reducing your amount of processors to an odd amount 1/3/5/7 etc fixes most RTAS overload issues. chris
Hello! Sorry for my late answer but I´m really busy!
Thank you very much! Changing to 7 Processors made it better, but CPU usage is still rising (slower than before), but I could finish the mix in one run! Here are my Playback Engine settings: 256 Samples, 7 Processors, 85%, Host Engine Off, 128 Voices, 44,1, Long, Level 2, normal, Plugin Sreaming Level2. |
I still have trouble with delayed tracks in my sessions!
Even just a drum mix gets out of sync after a few runs and edits. I have to close session and Pro Tools to fix that! DrumMix: 15 Tracks - SSL EQ, MASTER X, EQ3, Lexicon Plugin |
I would try reapplying the combo update of 10.5.8 since your processor is getting taxed.
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
I still have problems with long sessions!!
I have to mix a live album step by step!! After 10 Minutes CPU(Rtas) has increased form 30% to 100%!!!! HELP!!!!!! Please! |
This was a problem that plagued post production mixers who used one of the older versions of the Cedar plugin. Using an earlier version of the plugin or the newest update resolved the problem.
If you aren't using the Cedar plugin, I would try removing all non-Digidesign plugins from the plugin folder and seeing if the problem goes away. If it does, start adding the plugins back to the folder in small groups, rebooting each time, until the problem recurs, which will point you to the offending plugin. If removing all the non-Digidesign plugins does not make the problem go away, it obviously is not a plugin problem, so you will have to look elsewhere. I would guess it might be a corrupted session template or a faulty installation of Pro Tools. Just a guess.
Gary Gegan |
Excessive Processor Usage and Temperature: Avid 002 & 003 Family Driver | Mike Harrison | macOS | 10 | 08-15-2014 02:54 PM |
Excessive Processor Usage: Avid 002 & 003 Family Driver | Mike Harrison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-28-2013 02:14 PM |
Excessive Pro Tools LE CPU Usage even with no session open | jallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-06-2007 03:55 PM |
TL Space excessive CPU usage bug | Matt82au | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-06-2007 08:45 PM |
PT RAM Usage 389MB - Excessive? | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-20-2006 06:26 AM |
