easy way to convert a real kik drum into a midi file with 7
hay was woundering if anyone had a methoed or knew of a plug in that could convert a recored kick into a midi file for triggering a sampled kick as a replacement in pro tools 7.3. i havn't had a drum problem like this in a long time and was hoping that there was a simpler way in pro tools to do it than the old school way with a gate.
thanks |
Re: easy way to convert a real kik drum into a midi file with 7
I don't think it is possible in pt, the only way I can think of is to somehow get a midi triggered gate which then transmits info to a new midi track.
It is possible in Logic with the audio>midi function. Something like sound replacer does what you are talking about.
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4 |
In case you got the FXpansion VST to RTAS wrapper: there is several free VST plug ins, that can do this. It is also possible with Melodyne, or with an external drum-to-midi interface like Alesis D4 etc. Maybe you have something like this in your setup...
Or try to get the 14-day trial version of Sound Replacer or TL Drum Rehab.
MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire |
i wasx tryin to avoid the alesis methoed because that is the way i have done it in the past. was just hopin there was a simpler way.
I have been doing it in Logic for years. Now there is a new way by using Melodyne.
Load the drum track and choose file: export as midi file |
Convert .SNG to .MIDI file extension | grendizer | Pro Tools 10 | 0 | 11-26-2013 02:08 AM |
Question: Converting an audio drum file to a MIDI file? | ctyelvis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-18-2010 06:56 AM |
Could someone please convert a MIDI file? | TLarvenz | Pro Tools TDM Systems (Mac) | 9 | 08-22-2006 11:57 AM |
easy Drum machine/MIDI ?uestion.... | cerebral | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-01-2005 06:18 AM |
I desireth to rightclick midi file to convert it to Wav file | GuitarEasley | General Discussion | 17 | 08-27-2003 11:04 PM |
