Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 08-22-2023, 10:16 AM
Goombot Goombot is offline
Default Re: MTRX2 word clock v Sync X word clock
Right. With thunderbolt as the playback engine and no Dolby Audio Bridge. Correct?
Old 08-22-2023, 10:17 AM
its2loud its2loud is offline
Correct. Both Pro Tools and Dolby Renderer will be using the same Thunderbolt audio device. Sharing the available 256 channels via TB.
Old 08-22-2023, 10:26 AM
Right.
Old 08-22-2023, 10:29 AM
And even if you needed sync to the Renderer, which you really don’t since you can bounce everything in Pro Tools, you could just use the Dolby LTC plug-in to send TC to the Renderer. You don’t need a Sync X to do that.
Old 08-22-2023, 11:08 AM
gives's Avatar
gives gives is offline
Originally Posted by Goombot View Post
Thanks for the detailed response. So what I'm planning on adding to my MTRX2 is the thunderbolt option card and the new Focusrite PCIe Dante card. I was planning on having the thunderbolt be the main playback engine and the Dante card as the routing to the renderer 128 back and forth and having the sync setup left alone. Is there any reason that won't work? Sorry for not being clear about my future purchases.
the way I'm going is the TB3 option if it ever gets here. Not sure about all of this that you are saying, but essentially it will eliminate the infamous Dolby Audio Bridge for me and having to launch into that, which is OK but the TB3 option is much better and also will let you go directly into the Mac Studio. Love my new MTRXII and was able to sell my mint MTRX that was barely 2yrs. old to a post house in LA for about 6k with the SPQ, Dante and MADI included, since that it all on the new MTRXII. Someone told me that they had tested running 96khz ATMOS sessions with S6 for days without a problem this way, so there you have it. The rest I am not sure about, but the clocking for me is solid for now. Simply connect one of the TB3 connectors from the installed option card on MTRX II to one of your TB3 busses on the Mac Studio. Yes, you could use either the HD Native engine or a playback engine specific to the TB3 option card (Coreaudio). The TB3 use case for the Dolby Renderer is very clean, powerful and qualified. All of the IO latencies are comparable between MADI, Dante and TB3 so that's not really a factor. In the middle right now so hopefully this will help answer.
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
PT8//Word Clock//Loop Sync//Big Ben whatsprotools Pro Tools TDM Systems (Mac) 13 02-27-2009 10:56 AM
Word clock sync goga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-11-2008 11:28 AM
Has anyone got a 003r to sync via word clock? amverdile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-16-2007 09:44 PM
L2 won't sync to 192 Word Clock Studio Dweller Pro Tools TDM Systems (Mac) 5 10-23-2003 06:50 AM
Sync / word clock help needed stufflake Pro Tools TDM Systems (Mac) 4 12-08-2000 12:26 AM
