Old 07-07-2015, 02:00 PM
jzaid22 jzaid22 is offline
Default Crackling and Static on Pro Tools 11
Hey guys,
I've been running Pro Tools 11 for a while now in order to record drum tracks in my home studio. I've been relatively problem free until recently. Now, when I play back tracks, I get static and crackling which often delays my file mid-playback. It seems to be in random spots, and the amount of tracks doesn't seem to have an effect on the static- it happens with big files or very small files. My interface is a Tascam 1800, set to the highest latency. Sandra report below. I really appreciate any help!
-Josh
SANDRA REPORT
ID
Host Name : Josh
Workgroup : WORKGROUP
Computer
Model : ASUS S500CA
Serial Number : D1N0AS2********
Chassis : ASUS Notebook
Mainboard : ASUS S500CA
Serial Number : BSN1234567**********
BIOS : AMI (OEM) S500CA.204 02/05/2013
Intel vPro : 8.01.02.1318
Total Memory : 3.89GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz (2C 4T 2.8GHz/3GHz, 2.8GHz IMC, 2x 256kB L2, 4MB L3)
Socket/Slot : FC PGA988
Chipset
Memory Controller : ASUS Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 4GB DDR3 SO-DIMM 1.6GHz 64-bit, Integrated Graphics
Memory Module(s)
Memory Module : LG [Empty] 4GB DDR3 SO-DIMM PC3-12800U DDR3-1600
Video System
Monitor/Panel : AU Optronics Generic PnP Monitor (1600x1200, B156XW04 V5
, 15.3")
Monitor/Panel : FNI LCD TV
(1600x1200)
Video Adapter : Intel(R) HD Graphics 4000 (16CU 128SP SM5.0 350MHz/1.15GHz, 32MB DDR3 1.6GHz 64-bit, Integrated Graphics)
Graphics Processor
OpenCL GP Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.15GHz, 1.8GB DDR3 1.6GHz 64-bit, Integrated Graphics)
Compute Shader Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.15GHz, 64MB DDR3 1.6GHz 64-bit, Integrated Graphics)
Storage Devices
Hitachi HTS545050A7E380 (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 466GB (C:)
SanDisk SSD U100 24GB (24GB, SATA600, 1.8", SSD) : 22GB
WDC WD10JMVW-11AJGS3 (1TB, USB2/SATA300, 5400rpm, 8MB Cache) : 931GB (D:)
Logical Storage Devices
Windows (C:) : 444GB (NTFS) @ Hitachi HTS545050A7E380 (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
My Passport (D:) : 931GB (NTFS) @ WDC WD10JMVW-11AJGS3 (1TB, USB2/SATA300, 5400rpm, 8MB Cache)
Recovery : 900MB (NTFS)
Hard Disk : 350MB (NTFS)
Restore : 20GB (NTFS)
Peripherals
LPC Hub Controller 1 : ASUS Panther Point LPC Controller
Audio Device : ASUS Panther Point High Definition Audio Controller
Audio Codec : VIA 8446
Disk Controller : ASUS Panther Point Mobile 6 port SATA AHCI Controller
USB Controller 1 : ASUS Panther Point USB xHCI Host Controller
USB Controller 2 : ASUS Panther Point USB Enhanced Host Controller #2
USB Controller 3 : ASUS Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour)
Printer : HP Officejet Pro 8610 (600x600, Colour)
Printer : HP Photosmart C309a series Class Driver (600x600, Colour)
Printer : HP Photosmart C309a series Class Driver (1200x1200, Colour)
Printer : HP Photosmart 5510d series Class Driver (600x600, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Peripherals
Media Player : WD My Passport 0830 (931.48GB)
Network Services
Network Adapter : Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller (NDIS 6.30) (Ethernet)
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Wireless Adapter : Qualcomm Atheros AR9485WB-EG Wireless Network Adapter (802.11n (HT), 72.2Mbps)
Power Management
Battery No 1 : ASUSTek X502--40 45.34Wh/4.03Ah
Operating System
Windows System : Microsoft Windows 8.1 Home 6.03.9600
Platform Compliance : x64
Windows Experience Index
Current System : 4.7
PC: ASUS S500CA
Windows 8.1
Intel Core i7-3517U CPU @ 1.90GHz 2.40 GHz
64 Bit OS, x64-based processor
4GB RAM (Currently 3.89 GB available)
Pro Tools 11.0.1
Audio Interface: Tascam US-1800 (Version 2.02 connected through USB 2.0)
Old 07-07-2015, 04:21 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Crackling and Static on Pro Tools 11
There are three things I see that may be contributing to your issue.
1.) Only 4GB of memory. Adding memory would give your system more breathing room.
2.) Intel integrated graphics. Although not a bad thing by itself, it does share system resources, which are a little limited on your system. Again, adding memory may help.
3.) 5400 RPM drives. You should be recording to a 7200 RPM drive, and make sure it is not the same as your system drive.
Will
System Details
Old 07-07-2015, 04:50 PM
mesaone mesaone is offline
Dual core 1.9 GHz is probably not helping much, either. I'd be inclined to borrow someone's interface and test it against the tascam, given the nature of your issue.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 07-15-2015, 08:01 AM
Thanks for your responses, guys! I really appreciate any advice. I just think it's strange that I've been running Pro Tools without an issue for about two years now and only now is it giving me problems
PC: ASUS S500CA
Windows 8.1
Pro Tools 11.0.1
Old 07-15-2015, 08:09 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
I think the default setting for Windows 8 is to defragment the disk drives in the background. Perhaps it is defragmenting when you are working with Pro Tools, affecting the drive performance. You may want to change that setting and manually defragment when you are not using Pro Tools. As previously mentioned, the 5,400 rpm drives are not suitable for Pro Tools.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 07-15-2015, 04:04 PM
8dB.co.uk 8dB.co.uk is offline
Don't know if the Tascam is like my Motu, but I found it very easy to clip the analogue outputs, resulting in crackling. My RME seems to have far more internal headroom. Are you seeing any clip lights on your master output meters?
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
Old 07-30-2015, 08:17 AM
No everything on my meters is reading normally, and there doesn't seem to be any correlation between what is happening with levels or music and the crackling. It seems to me that it is completely random.
I've been looking into Solid State Drives and I'm thinking about picking up a Samsung Evo 850 256gb. Do any of you guys have any experience with this piece of hardware?
PC: ASUS S500CA
Windows 8.1
Pro Tools 11.0.1
mbox2 crackling/static...!!!! 5teph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 06-22-2023 12:19 PM
Pro Tools Crackling / Static on playback when mixing asaffulks Windows 21 09-12-2013 03:24 PM
8.0.4 Strange Crackling and Static. philip888 General Discussion 0 07-15-2010 07:44 AM
Need of help of Static Crackling Sound!! acuraboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2008 07:11 AM
Static/Crackling Noise DoubleDigit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-22-2003 04:23 PM
