Old 12-27-2009, 05:33 AM
goga goga is offline
Default Stylus & Omnisphere...help?
I try to get Stylus to send signal on all the outputs, on different chanels in PT. I just cannot figure out why I cannot hear the output A. I have a chanel in PT where Stylus is set as a plug, and it's sending outputs A-H to different channels. But there is no sound onto PT, althoug I see signal coming out of Stylus on output A! I do hear all the other outputs. I have exaclty the same setup for the Omnisphere and it works perfect, A-H putputs on different channels.
Any help?
Old 12-27-2009, 06:14 PM
Default Re: Stylus & Omnisphere...help?
Bump... Help?
Old 12-27-2009, 09:52 PM
Larold Larold is offline
I remember something about stylus...I think you have to set the input to SOMETHING...it won't play without an input assigned to that channel. It's late, and I'm tired, but your post rings a bell.
Good luck. I know it's frustrating. Also, make sure you have the latest version from their website.
Old 12-28-2009, 12:25 AM
L-Dogg L-Dogg is offline
Go to Spectrasonics>Stylus RMX Support>Video Tutorials>You can find all of the latest tutorial videos HERE>RMX and Pro Tools 7
It is a great video that will explain it all.
Now......I had an audio problem when I first got it and had to call tech support. Damned if I cannot remember what sorted it out....but I vaguely remember it had to do with clicking on the little grille right underneath the Power Filter area.
I am away from my studio but it seems there was some sort of option available under there.
God knows I could be entirely bloody wrong about this....but give it a crack. LOL I might be blowing smoke out the old you know what.
Tomorrow I will have a look at it and see if I can offer more suggestions. Try that video...it explains it well.
Mac Studio M2 Max
12-core CPU, 38-core GPU, 16-core Neural Engine
64 GB memory
2TB Solid State Drive
Thunderbolt 4
Sonoma 14.1.2
Pro Tools 2023.9
Universal Audio Apollo 8P (TB3 Option Card installed)
Omnisphere and Stylus RMX: sounds are playing back "glitchy" sylviesongs Virtual Instruments 0 10-25-2011 12:35 PM
Unexplainable LE crashes with Stylus, Omnisphere BJammin222 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-20-2009 06:48 PM
Quantizing to grooves using ProTools, Stylus RMX and Omnisphere question... Violet Virtual Instruments 2 05-29-2009 04:08 PM
PT 8, CPT works! With Stylus and Omnisphere. Larold 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-28-2009 08:34 AM
003 automation for Stylus&Omnisphere goga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 12-11-2008 04:03 AM
